Electrical Led bulb fitment
Led bulb fitment
hi anybody can confirm if this led bulb fits to rear turn signal indicator(clear lens)?
http://www.ebay.com/itm/2X-7507-PY21...6b379c&vxp=mtr
i am planning to replace the stock amber bulb with led bulb.
You will probably not be happy with that bulb, and chances are it won't fit well.
Try something more like this one:
http://www.ebay.com/itm/2x-7W-CREE-Q...item4603d25014
(Note that this is a BAU15S, which fits the front turn signal housing; for the rears you may want a BA15S - you should check before ordering)
= Mike
= Mike
Does that CREE bulb have a flash fixer resistor built in? . . . .
found it
[FONT=Arial][SIZE=2]"This LED Light will Not work properly on latest/European cars with OBC CAN Bus wiring system (shows Error message), unless with a Load Resistor installed in the circuit". In the mini it will likely have that error message even with the load resistor.[/SIZE][/FONT]
I love that projector and I have CREE back up lights (which were about 1/4 the price of these) but I can't justify 42 for a small increase in brightness over the turnsignal LED's I am already using (basically the same wattage or more without the projector). If the CREE had a working flash fixer / error eliminator I think I would bite though.
found it
I have no idea what a "flash fixer resistor" is, so I can't answer for sure.
The Mini doesn't have the "fast flash" indicator bulb-out warning behaviour (it uses the OBC to warn you instead). In most cases, when replacing the turn/brake/reverse lights with LEDs, you will want to code out the bulb checks (or find a friendly local to do the coding for you... it doesn't take long).
= Mike
= Mike
should i replace my standard city lights with these philips leds or i will face issues with bulb warnings?has anyone experienced these leds to tell me?
http://www.ebay.co.uk/itm/LED-PHILIP...item3cc1221f27
= Mike
= Mike
mini mini Those do not look like they would draw enough power to avoid a bulbout, I am using these:
http://www.ebay.com/itm/2X-White-13-...44bf3b&vxp=mtr
Yes the cheap Chinese ones and they don't throw a bulbout code on my 2009 but they do on my 2010. I have gone though 2 sets in 3 year so far so they hold up great for how cheap they are. They are bright enough for DRL use and at $2 each you can afford many spares.
https://www.northamericanmotoring.co...1/ppuser/17546
I am about to switch to these but I am on the fence:
http://www.ebay.com/itm/2X-WHITE-T10...e62802&vxp=mtr
They should project light way better but with no reflection from the housing the light will appear to come from a single point. So it could be an expensive step backward.
mini mini what year is your mini?
10-01-2015 12:13 PM
09-30-2015 11:39 AM
09-29-2015 12:17 PM
09-29-2015 12:16 PM
09-29-2015 12:11 PM
