ElectricalFor discussions regarding wiring up electrical modifications such as radar detectors, brake light mods, power sockets, and driving lights in Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
Is it possible to have the High Beams and the front fog lights on at the same time? Perhaps coding in NCS Expert?
I have seen on other BMW boards the following value on LCM module, but not sure if it is the same on R56:
FL_UND_NSW_NICHT_GLEICHZ - front fog lights not simultaneously with high beams
aktiv
Sorry, not an NCS expert but I'm sure there must be some way to do it by merely making a few wire splices. I presume you're running oem fogs and driving lights. All you need to do is convince your fogs to stay on anytime the switch is on and the parking lights are on (vs low beams).
This is a sensitive topic, how dare someone want to use high beams and fog lights, how about high beams, driving lights and fogs ALL at the same time? I like as much light as possible when driving on a dark road. Just my opinion.
