Electrical Rallye 3000 headlights
Old 06-21-2013 | 09:40 PM
jrhavener's Avatar
jrhavener
ok,
so i've mounted the lights, i have a switch in the car.
i've got everything wired right i think, but i keep blowing fuses. the only part of the circuit i'm not sure about is the control circuit... where should i be getting my signal from?
i tried using the battery as a source... everything works but when i flip the switch the fuse pops
i have battery going to the switch part of the relay with a (currently) 10 amp fuse (i have 1 15A left, a bunch of 10s and 5s)
that goes to the switch side of the relay
the other side of the switch goes to the lights
the lights then have a ground.
the control side I tried grabbing the signal from the low & high beams, and the battery. either way i wired those to the coil side of the relay
the opposite side of the coil goes to the switch on my dash, then back out to a ground.
any thoughts? i'm hoping to get them working for MOT tomorrow, but I just finished a 14hour shift and I'm beat... any help is greatly apreciated, but i'm gonna have to call it quits soon anyways.
maybe next years MOT? lol
thanks
j.r.
Old 07-15-2013 | 10:22 AM
heresmymind's Avatar
heresmymind
you probably have a bad ground, or a bad circuit. what type of relay and wire harness did you use? and how did you hook it up
-B
Old 08-08-2013 | 04:34 PM
MotorWorf's Avatar
MotorWorf
I'm trying to locate a good ground under the driver's side knee panel for a driving light switch (has a built-in ON light)
Old 08-08-2013 | 04:50 PM
danjreed's Avatar
danjreed
You have a dead short somewhere if it blows when you flip the switch.. The short is between the relay's switch and the lights.
(Edit if wired as a power side switch..)
+ signal > 85 (relay) 86 > switch > ground
Battery + > fuse > 30 ( relay ) 87 > light > ground
I would take the + signal off the high-beam power wire. That way they will only function with the brights. (And be road legal).
There should be a good ground lug under the kick panel.. If not make one. Drill/nut/bolt
OutMotoring
03-03-2017 07:29 AM
DTIREY
R55 :: Clubman Talk (2008+)
09-29-2015 02:00 PM
09-29-2015 01:17 PM
09-29-2015 01:16 PM
09-29-2015 01:11 PM
