Electrical The Foot Well Module: functions, problems, solutions?
Old 02-04-2024, 09:14 AM
RoadTripMachine's Avatar
RoadTripMachine
RoadTripMachine is offline
Originally Posted by RainRainGoAway
I highly suspect that I have an issue with a footwell control module ground/earth. I've tried to figure out where/what/how, but even with a Chilton's repair manual with wiring diagrams I haven't be able to figure it. Anyone have an idea that might help me out?
It's worth spending the money on the Bentley manual for these cars. It's only available in hardcover (as opposed to .PDF) and it's typically around $150 on amazon - but it's worth it. It's the size of a college text book and is the best resource you'll find for working on these cars. It's good enough that I can appreciate why they haven't resorted to (easily pirated) digital versions.
What problems are you having that seem like the FRM?
  #327
Old 02-04-2024, 09:26 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Originally Posted by RoadTripMachine
- Thank you for your input. I'm just not getting back to working on this.
- Installed ISTAP and currently reading up on it before connecting to the car. Any pointers for keeping ISTAP contained?
- My head unit is already bugging out and my amp makes noise when it's off - so it'll all get replaced soon regardless. Seems a good time to learn to run ISTAP without too much risk - so it'll be safer to run when I get the next mini.
- Running the kdcan cable as well, but the impression I get is that the ICOM helps act as a buffer for slower PC's similar to the hardware controllers I use for CNC equipment - where older PC's could easily be interrupted by multitasking or running out of cache memory.
For istap, once the tree is populated after calculating the test plan, you could right click on the module that you don't want to mess with and remove it from the plan. The issue with istap is that it lakes time to load and them more time to excute. Winkfp is the friendlier version of istap. You hand pick the module and your good to go. Then, use ncs expert to code that module.
RoadTripMachine (02-04-2024)
Richie the C
Electrical
10-08-2022 05:01 PM
TiggerGTO
Electrical
24
04-19-2012 03:27 PM
MiniPOLACK
Electrical
03-26-2012 07:55 AM
BEAVR
11-20-2010 03:17 PM
namwob
14
03-23-2005 05:15 PM
Quick Reply: Electrical The Foot Well Module: functions, problems, solutions?
