Electrical R53 goes completely dead
Old 04-21-2015 | 03:46 PM
DougFresh's Avatar
DougFresh
Hi I have a 2005 R53 that would loss all electrical power while driving. It actually happens when I'm usually making a turn in 1st going into a driveway or parking spot or while backing up into the same. The car will just loss all power momentarily and then come back on!! Except for the other day. The car lost power ( no dash lights..nada), no motor cranking or anything. Later after bouncing the car power came back and would crank but no turn over. Then later it started. Any ideas??
Old 04-21-2015 | 04:02 PM
MINIAC's Avatar
MINIAC
How old is the battery?
Old 04-21-2015 | 04:25 PM
DougFresh's Avatar
DougFresh
Less than 1 year
Old 04-21-2015 | 04:26 PM
ZippyNH's Avatar
ZippyNH
check the ground wires...both under the hood by the passenger side motormount, and the battery.....
Old 04-21-2015 | 04:27 PM
ZippyNH's Avatar
ZippyNH
turning over = cranking......
are you saying you can spin the motor, but not start it?!
Old 04-21-2015 | 05:04 PM
DougFresh's Avatar
DougFresh
I will check both grounds, Thank you
Old 04-21-2015 | 05:09 PM
DougFresh's Avatar
DougFresh
Yes, turning over = cranking. It cranked numerous times without starting with no smell of gas, I had a full tank. Then I let it sit for about 30 minutes and then it started.
It seems to happen when I have the clutch depressed. Is there a know problem with an electrical connection at the clutch?
iggi
17
09-02-2023 03:06 PM
maniacalmorgan
38
09-29-2015 04:56 AM
Chasp
09-15-2015 03:26 AM
Super Coop
08-17-2015 05:09 PM
Herleman
08-16-2015 06:41 PM
Quick Reply: Electrical R53 goes completely dead
