Electrical Alta boost gauge help
on
So I installed my battery yesterday and changed the Alta boost gauge sender to the water proof sender. Everything seems to be working but I have a couple concerns. 1. When your car is on idle should the needle be at 0? Mine is at the bottom, I think at 20??? 2. I had it set up before when if my dash light was on the brightest setting it would be orange and when I turn the lighting down 2-3 brightness the boost gauge would turn white. Now, when I turn it down the entire boost gauge shuts off. Did I install the two connectors on the back of the boost gauge wrong?
Your boost gauge at idle should be reading vacuum. Usually around 20 when your car is warmed and 10-15 ish when you cold start it. As far as the lights go, I don't have an answer for you because I still don't have my backlight set up on my boost gauge but I'd say it sounds like a connection problem.
on
http://altaperformance.com/attachment/74764-.pdf
I have the same boost gauge, I (mostly) followed these instructions when I installed mine.
Since the gauge came with the plug n play wiring it's really easy to disconnect the gauge and look at the connector, to see if it's even possible to plug it in improperly.
In my experience, the gauge will turn back to white if I dim the dash low as well. I would check all the wiring if it's not the connection at the gauge.
If your sender is mounted in the engine bay, I'd also check it out to see if it's gotten wet or anything.
On a side note, I opted to run the vacuum tube through the firewall plug and into the cabin, and mounted the sender near the OBDII port. I think that's more sensible than leaving a sensitive part like that exposed to the elements as they make it into the engine bay.
on
on
uslfcfan
Electrical
18
05-30-2016 11:24 PM
mmdouglas
02-04-2016 06:36 AM
