How To Anyone want to help me program for my 25w Xenon retrofit lights?
Hi, I have seen a number of posts for folks successfully programming their Xenon retrofit lights with NCS software. I am not super tech savvy, but I would offer to Venmo someone the $100 to walk me through step by step, instead of giving that money to the dealer. Let me know! I have a 2010 Clubman S.
thanks! I will buy those things, but am really worried about screwing up the coding. Reading codes are a different story. I need hand holding!
Do you know, is that app only for Android devices?
It's only available on android at this time. In my opinion, it is worth picking up a cheap or used Android tablet or phone just for this tool.
I've only used the K+DCAN. I've had mixed experiences with K+DCAN that I have found on Amazon, but the Bimmergeeks cable has worked great. You should only need one or the other.
Here is quick DIY for the Bimmergeeks Protool:
1. Tap "Vehicle"
2. Tap Vehicle Order.
3. Tap Edit
Note: You will be prompted to save a backup of the Vehicle Order.
4. Select Add-Ons.
5. Select X25W: RETROFIT 25W XENON HEADLIGHT NA 190572
6. Select Actions.
7. Select Save.
Note: You will be prompted to code modules that are related to the changes made as well as the CAS and FRM.
8. Return to the main menu.
9. Select Safety.
10. Select FRM.
11. Select Coding.
Note: you will be prompted to make a backup.
12. Select Standard.
13. Change the following:
a. Cold Check High Beams
b. Cold Check Low Beams
c. Left Lwr Error
d. Right Lwr Error
e. Hot Check Hight Beams
f. Hot Check Low Brams
g. Xenons Installed
14. Select Finalize.
Note: You will be prompted to cycle the ignition.
That should do it.
1. Tap "Vehicle"
3. Tap Edit
4. Select Add-Ons.
6. Select Actions.
7. Select Save.
9. Select Safety.
10. Select FRM.
11. Select Coding.
c. Left Lwr Error
d. Right Lwr Error
g. Xenons Installed
That should do it.
Gubi (09-26-2023)
1. Tap "Vehicle"
3. Tap Edit
4. Select Add-Ons.
6. Select Actions.
7. Select Save.
9. Select Safety.
10. Select FRM.
11. Select Coding.
c. Left Lwr Error
d. Right Lwr Error
g. Xenons Installed
That should do it.
1. Tap "Vehicle"
3. Tap Edit
4. Select Add-Ons.
6. Select Actions.
7. Select Save.
9. Select Safety.
10. Select FRM.
11. Select Coding.
c. Left Lwr Error
d. Right Lwr Error
g. Xenons Installed
That should do it.
scotty_r56s (06-11-2021)
I have tried it with auto detect, R5X series, connecting and powering differently about everything I can think of including setting the vehicle back to factory with NCS Expert yesterday and it still will not connect. I have BimmerCode nd BimmerLink on the same tablet and they connect no problem.
I searched their FB page and didn't find a similar issue, submitted the question and about the only response I get is what version am I using.
Cutting11S
01-16-2011 05:24 AM
