Electrical F56 2015 Mini Cooper S - Replaced LED Headlights - Coding Data invalid
I have a 2015 F56 Mini Cooper S that I hit a deer in the damaged the hood and drivers side headlight. I purchased a 2017 F56 for the components that I was needing and I used both LED Headlights off the 2017 donor car to put in my 2015 Mini Cooper S that had what appears to be the exact same headlights.
I am now getting the following errors:
Front Light Left Coding Data Invalid
Front Light Right Coding Data Invalid
I found these errors using Bimmer Code and they are the only errors that I am seeing. that are RED in color
Can anyone point me in the correct direction to rectify this issue with the headlight coding it would be greatlt appreciated.
I feel that is all I will need to finish reassembling my Mini!
i do appreciate that info and I will let you know how it goes!
Pkupthpace
02-04-2020 03:23 AM
