Electrical 2005 Rear Fog Brake light Kit
I thought I saw one of the vendors offering a kit for a "4th brake light" to go in place of the fog light insert in the rear bumper. Does this ring a bell with anyone? I can't seem to find it.
Or, does anyone know if I could do this just ordering specific parts from the dealer? I have a 8/05 build MCS. If so, what would I need?
Thanks,
John
Thanks,
John
The vendor is MyMiniParts.com.
You can make it an extra brake light: http://myminiparts.com/proddetail.php?prod=MMBLK
or an extra backup light: http://myminiparts.com/proddetail.php?prod=MMBUL
Originally Posted by m3yeh
Hello,
Is this a 'plug and play' type of installation? Do I need to splice the factory wiring?
Thanks in advance,
Thanks in advance,
john
BT,DT. It's a 20-minute install.
Beware that the supplied directions may not be correct for a late `05 build, unless he changed them in the last two weeks. I used the third backup light option.
The issue is that the wires running to the factory installed wiring and plug at the light are described as being in a 2-wire separate bundle. In fact, on my August`05 build MCS, the brown/yellow wire to the light was contained in a six-wire bundle with three grey wires.
Call him before starting, to check on the directions. Also, I strongly suggest verifying that the supplied circuit tester is functional. Check it across the battery before depending on it being functional...
Thanks for the update on the later 2005 build I will add it to the directions. Did you by chance take a photo of it so I could add it to the instructions?
I have added information about the additional wires and also thanks for the feedback on the test light. I ordered in bulk and did not think about testing them. I have tested all the remaining testers and have found another bad one. Sorry if it caused you any problems.
Thanks,
07-16-2020 12:54 PM
12-23-2015 10:36 AM
