Electrical Factory fog light default on?
Oh cool. There's an add-on for the fog-lights to the auto-up circuit.
Every car I've had with fog-lights has had an on/off switch for the fogs, but 'on' meant on only when the mains were on. I've never found them particularly useful while driving in actual fog, but they do a good job lighting up those roadside critters.
I've had Ian's circuit since I bought my Mini. After using it for a month, I turned off the auto-foglights feature permanently, because it reduces your ability to see the road.
The additional light from the fog lights makes your brain think that it is lighter out than it really is, so your eyes adjust by making your pupils smaller.
The result is that you cannot see the road as well, even if you can see the bushes on the side better.
You can easily verify this while driving on an unlit road at night: with fogs off, and continuing to look straight ahead, turn on the fog lights, and you will almost immediately notice that your view of the road becomes dimmer.
Auto-on foglights (or driving with them on when it isn't foggy) are a really bad idea for this reason alone, not to mention that it is illegal in most states, and pisses off a lot of other people. I often flash high-beams at thoughtless drivers who leave their fog-lights on - it's really a slap in the face to others.
I'd sell you my AFF circuit for $1, if it wasn't a PIA to remove it.
Flame away - I couldn't care less...
That is cool, i am always having to switch on the fogs when i turn on the headlights, i actually think it would be cool to have the Fogs function like DRL coming on when the car is on, cause often times i run even during the day with fogs on. This is a good idea, i will definitely get one.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
08-19-2015 12:51 PM
