Electrical Rear spoiler brake light flasher module
Yeah, I know.....been there, done that....but, just say, I want to change from the one I have now. What others are available? Anybody know? I had the "Back-Off" that flashes 4 times, pauses, then flashes 4 times again and never goes completely steady. At present, I have the IBF9 (I think that's what it's called). It flashes MAYBE 9 times and then goes steady, but more times than not it only flashes 7 max. Okay, I'm open for suggestions.......GO!
I really like the one I just got from NAM sponsor GoMiniGo. Read my writeup here:
http://www.jwardell.com/mini/2006/09...d-brake-light/
Although I like the quicker flashing version above...
You may want to look at this one from Kisan, http://www.kisantech.com/view_product.php?product=200GW. I have a similar Kisan unit on my morotcycle. Kisan's products are expensive - no doubt, but the flashing pattern is the most effective that I'm aware of. I will probably swap out the Comagination for the Kisan. If you order from Kisan, when they ask, tell them you're a member of the BMWOA (BMW Motorcycle Owners of America) you'll get a discount.
Yeah, it's me that has this annoying brake light flasher .
It may fit but it only works on bulb type lights not LED's. Read about the products they sell they sell an LED one but it is configured for plug-n-play for motorcycles (goldwings). Ours is only for LED and does the same quick four flashes.
I had the "Back-Off" module on my red Cooper. It blinks a steady four blinks then goes steady, then starts all over again with four blinks and a steady. I now have the IBF9 (quarter sized hockey puck shape) in my "S" JCW that is supposed to blink up to 9 times then go steady and stay there. Depending on how long it's been since the circuit has been activated, it blinks between 4 & 7 times then goes steady. I'm not too sure I'm real crazy about either one, but they're better than nothing at all, I'm convinced. I think the Back-Off one IS programmable so you can have it go steady after 4 and stay steady while the brake is on. Maybe that would be the best for me anyhow. It's hard to install in a Cooper, but it can be done. The box is about the size of a credit card, only thicker and it's for motorcycles (Goldwings). Now I'm beginning to think that's the one I want.
I'm not sure that's true -
[/quote]
I was referencing to the 20GW and it states that it increases the abiltiy of the bulb, it does not state anything about LED lights. The other ones on their site state they do not work on LEDS, on the products with the LED in the name state they work on LEDs
[/quote]
Anyone have any experience with the LED brake light module from Signal Dynamics? Using Mode 2 of their BackOFF XP module ($40) seems to be less offensive for car use than some of the other motorcycle modules on the market today:
http://www.signaldynamics.com/produc...les/xp_car.asp
I think that I might pick up either one of BackOFF XP units or support GMG with their unit. I am leaning toward the BackOFF XP unit because it blinks slightly less fast than the GMG unit, but not nearly as slow as the VisiStop IBF9 unit.
ben
ben
The Back-Off is the one I had on my CR MC and it repeats the four blinks which annoys me. I'm pretty sure it can be programmed to hold steady after the first four blinks, but my dealership installed it without asking me which one I preferred. I know it AND the IBF9 both work on LED's though.
What did you think about the length of the flashing when you did have the BackOFF installed? Was it fast enough for your tastes? I don't want to annoy those behind me when we are stuck in traffic, but the GMG module seems a bit too brief and indeed just seems like a 3rd brake light short.
ben
What did you think about the length of the flashing when you did have the BackOFF installed? Was it fast enough for your taste? I don't want to annoy those behind me when we are stuck in traffic, but the GMG module seems a bit too brief and indeed just seems like a 3rd brake light short.
ben
ben
07-16-2020 12:54 PM
