Electrical Clear Tail Lights for 06 S with fog lamp?
Old 10-06-2006 | 06:54 AM
Dave69's Avatar
Dave69
I have an 06 S with the rear fog lamp. They make a clear tail lamp that'll fit this specific combo?
I actually ordered a pair I thought would work, but since my bracket that holds the bulbs is L shaped, to incorperate the reverse light, they won't fit all. Any suggestions?
Old 10-06-2006 | 06:57 AM
meg's Avatar
meg
I have the 02-04 clear taillights on my vert. You need to make some changes to the bulb bracket that comes with them. Remove the top bulb and replace it with a clear one (this will act as your reverse lights). I also changed out the bottom bulb with a brighter LED red bulb (this is your taillight and brakelight). The middle one will be the turn signal.
Old 10-06-2006 | 07:14 AM
Dave69's Avatar
Dave69
Awesome Meg thank you.
I actually have the same tail lights as those but you just told me what my problem is. I don't have the straight bulb bracket, mine is L shaped.
So I need to find a straight bulb bracket, right?
Old 10-06-2006 | 07:47 AM
sagworks's Avatar
sagworks
running with scissors
To use 02-04 taillights on a later model, you do need to get a new light assembly from an 02-04 car. You can get them from the dealer for about $12 for the pair. Also you'll want to get colored bulbs - the ones stock in the Mini are clear blubs for colored lenses. I have clear lights (soon to be) everywhere and LOVE it on an AB.
Old 10-06-2006 | 11:08 AM
meg's Avatar
meg
Yes, although the clear lights I got came with the straight bulb bracket. The ones I have are the offical MINI ones (I know there is a similar aftermarket one). You could call MINI and see if they sell the bracket alone.
Unfortunately the bulbs are soldered in...we tried heating the solder to get them out and it didn't work. We wound up using a dremel to get the bulbs out to replace them.
Old 10-06-2006 | 01:15 PM
Dave69's Avatar
Dave69
Awesome, thanks you two.
Called my dealer, got em ordered and shipped. Should have em mid next week.
Thanks again for all your help.
Old 10-06-2006 | 01:18 PM
batgirlwildcat's Avatar
batgirlwildcat
It takes a little work to put pre-05 lights in a newer model, but it's worth it.
Old 10-13-2006 | 12:23 PM
MiniOwner2004's Avatar
MiniOwner2004
I love that lic plate!!
07-16-2020 12:54 PM
Sexual Chocolate
03-31-2019 08:02 PM
AZN Optics
Accessory Products
08-21-2015 02:03 PM
I_drive_slow
08-18-2015 10:47 AM
Powershift
08-16-2015 05:14 PM
Quick Reply: Electrical Clear Tail Lights for 06 S with fog lamp?
