Electrical Ham Radio Installation
I am a ham radio operator (KG6IFV) and will be getting my first Mini in the few days. I was wondering if anyone has installed a ham radio in their Mini. The power supply must be directly connected to the battery for the radio to work properly. Does anyone have any tips?
Thanks, Mike-KG6IFV
Thanks, Mike-KG6IFV
on
Cooper or S?
I ran auxiliary cabling from tghe engine compartment through the firewall and then along the rubber seals around the door into the boot area on my Cooper. I used 12 guage speaker wire with both conductors carrying the positive and then took a ground from behind the access panel. I had installed an auxiliary fuse panel up near the brake cylinder which was fed from the battery.
In the S it's probably easier as the battery is already in the boot area. I'll figure that out when I get my GP back from being repaired.
Chris
Chris
How big a draw do you plan on?
There are several "spare" but loaded fuses in most MINI's. The in cabin fuse panel is behind your left foot side panel. People have used the Add A circuit. The MINI has a big decal warning that any Non mini electronics, especially ham radio could screw it up. I have not heard of any problems. I have used my Ham 2 meter and commercial 450 HT's in the car with no effect on the car.
A friend of mine has his 2 meter powered directly from the "jumper cable" connection under the hood of his MCS, and has the Antenna mounted at the rear with a "hatch back" type mount.
KA9CAR
John
KA9CAR
John
I was just wondering about RFI, as it seems whenever I have used a pocket police scanner or HT in my 08 Cooper that whenever I lay it on the passenger seat I get all kinds of RFI. I bought a small Icom VHF-UHF radio with remote control head and wanted to mount the radio under the passenger seat.
Terry-WB0VQP
Terry-WB0VQP
squawSkiBum
10-02-2015 09:21 AM
