Electrical HEAD LIGHT problem
About how old are the bulbs? Are they OEM?
Loose conection sounds like a culprit is you pop your bonnet; the underside will have bludhe where the light is there is a metal spring clip, you can release that and bend back the plastic cover if they are the halogens (not xenons) then you should be able to see the plug, just check make sure its on tight.
Hope you can fix it easily and soon I know that kind of thing can be a pain and I'd hate for you to get a stopped or get a ticket cause the light decided to cut out.
07-16-2020 12:54 PM
phrza81
10-10-2015 11:37 PM
cm.d
08-19-2015 08:51 AM
jrezzo
08-09-2015 10:32 PM
