F54 :: Clubman Stock Problems/Issues (2015+) Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F54 MINI Cooper and Cooper S MINIs.
Rear Crossmember Vibration Damper gone bad again
Old 05-16-2023, 07:57 PM
blkpnts's Avatar
blkpnts
blkpnts is offline
Part 7 vibration damper gone bad again. Any consequences if I just delete?
Old 05-17-2023, 03:51 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Received 1,840 Likes on 1,467 Posts
How do you determine that a vibration damper has gone bad?
Old 05-17-2023, 06:40 AM
blkpnts's Avatar
blkpnts
blkpnts is offline
The rubber has come loose from the cast piece which now spins freely.
Old 05-17-2023, 07:04 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
I can only think if that piece is missing you'll probably just get a little bit more drivetrain noise, but might not be enough to notice.
Old 05-17-2023, 09:00 AM
ECSTuning is offline
Received 2,085 Likes on 1,860 Posts
Yep, seen those on other cars, first time for MINI. On Rover they are for off road so the frame does not create vibration. Some people remove them and they weigh about 50 pounds each on a rover
#6 does the same thing on the end near the wheel.
People on the BMW side complain about noises and its reduces noise by the tone or HZ
https://f30.bimmerpost.com/forums/sh....php?t=1788676
So removed you might get noises.
Old 05-17-2023, 01:31 PM
TVPostSound's Avatar
TVPostSound
TVPostSound is offline
When intact, its a "harmonic vibration" damper.
Easier for BMW to install those than redesign the crossmembers.
Old 05-17-2023, 04:39 PM
blkpnts's Avatar
blkpnts
blkpnts is offline
yeah I’m not concerned about noise, just making sure it won’t cause premature drivetrain wear or failure.
Would love to shed the pounds and stop replacing this 35khz damper.
Old 05-18-2023, 06:19 AM
Yep, no one i know of have tested this for MINI. My guess is just the noise.
Old 05-18-2023, 07:10 AM
TVPostSound
Understand, the vibration causes the noise. Like a violin string vibration makes noise. So will the crossmember.
Will that vibration cause cracking, time will tell.
RA080624
09-14-2007 10:19 AM
1nf3rn0
02-01-2007 11:45 PM
Gromit801
Northern California
10-25-2006 07:43 PM
Quick Reply: Rear Crossmember Vibration Damper gone bad again
