F55 Trunk Open Warning
I started getting this warning on ownership day3. I only unlock the driver's side door (verified in the setting) but apparently the trunk/ hatch gets unlocked as well for some reason. I have seen some threads with the same issue posted as early as 2014. Is this still a common problem? What is the resolution?
When I try to open the hatch without unlocking it first, the hatch does not open but I can move it up and down slightly. Is this normal?
Thanks in advance.
F55 S
Production Nov 2015
Thanks in advance.
F55 S
Production Nov 2015
Thanks in advance.
F55 S
Production Nov 2015
Thanks in advance.
F55 S
Production Nov 2015
The hatch should not, however, wiggle if you are not squeezing the handle. Open the hatch and give a close look at the latch on the gate and on the car to see if something is blocking it from shutting all the way. If it looks clear, I would schedule a service appointment right away.
Someone had a piece of cloth getting in the jam.
Here's someone struggling to keep the hatch closed:
https://www.northamericanmotoring.co...runk-door.html
I drop the hatch from about 3" and have never had an issue with it not latching. There is no "wiggle" if I tug on the handle away from the button when closed. The only issue I ever had was I used to keep the fob in my pants pockets and when seated I would occasionally activate the hatch button between me and the seat.
Yea the weight at that height should close it well. People had this issue back in the day with the gen 1 MINI on how to get to a point on closing the hatch.
watchluvr4ever
02-11-2016 10:04 PM
MiniPhan1030
01-01-2016 09:45 AM
JPeac2
12-28-2015 01:31 PM
