R60 codes galore + misfire/hesitation
Hey all so my 2012 R60 countryman all of a sudden decided to act up last night after filling up my gas tank. Shortly after filling up i decided to do a little wide open throttle (WOT) pull and all of a sudden the car fell flat on its face and the check engine light came up which put the car in limp mode. I shut the car off and turned it back on so it would exit limp mode and it did BUT anytime i would give it gas where the turbo would begin to spool it would begin to misfire.
This morning I decided to do a boost leak test and i found no leaks. I took the car to auto zone so they can read the codes and i have the following:
P0300 RANDOM MISFIRE
p0302 CYL 2 MISFIRE
p144b FUEL CONSUMPTION
p0304 CYL 4 MISFIRE
p15fd ???
I reset the ECU by accessing the service menu on the dash and still no luck, the Check engine light is still lit. I then disconnected the battery overnight and still no luck and i still have the same issue. Does anyone have an idea of what may cause this if it isnt a boost leak?
p0302 CYL 2 MISFIRE
p0304 CYL 4 MISFIRE
p15fd ???
I was hyper aware of the potential and I think I caught the issue before it got worse. As soon as the codes hit I made an appointment. I just had the hesitation at start up and sometimes momentary hesitations at highway acceleration speeds.
Check and see if the pump on your car is covered.
Ok i dropped the car off yesterday and picked it back up later that day. Dealer states that I need to replace the coils and plugs and that will resolve the issue. Since the coil packs arent cheap I opted to just purchase 2 of them for cylinder 2 and 4 and i bought a set of 4 replacement plugs. My question is what is the numbering scheme of the cylinders, is it Passenger side -> Driver side 1-4 or the other way around?
dyeLucky
11
03-28-2016 11:55 AM
Kahnfucious
03-18-2016 05:04 PM
jeanna
18
07-25-2002 03:25 PM
