2015 F55 maintenance/reliability
I have a 2015 four-door hardtop model. It has done 60,000 miles in the last 9 years, which is not much by Texas standards.
However, I had to do a lot more repairs in this car than I had to in the other ones (mainly Japanese) I’ve had so far. These are the things I had to do so far.
- brake fluid flush
- wastegate valve actuator repair
- coolant flush
- replace the rubber striping around rear doors
- replace engine mounts
- AC Schrader valve replacement
- replace windshield washer fluid pump
- replace crankshaft pulley and belt
- replace AC compressor
- replace upstream oxygen sensor
- replace fuel tank vent valve
- the AC unit has developed another problem now and the service department is asking blower control module to be replaced
Is this considered normal for these cars? I do not understand what I am doing wrong. The car is kept in a garage, driven less than average, oil change done every 6000 miles or so. Not sure what I should be doing differently to prevent any future repairs.
- brake fluid flush
- coolant flush
valvashon
03-16-2024 12:41 PM
