F55/F56 The New Key Fob for the F56
#251
my neighbors a lazy f*cking moron. saw him the other day and he goes "i owe you a call...been so busy"...no you're just a lazy *****. i gave up on him. if this ever finishes, i'll be glad just to forget about it. good luck Vic.
#253
#255
#256
I agree, it does look exactly the same. He said he widened it just a hair which we both thought would do the trick. The only issue with super gluing it would be if you go to sell the car and need to put the original back on.
#258
Secondly, it looks like radius of the top portion is still to small, you can see how the top of the circle doesn't sit as close to the key as the area around the side, it almost looks like the fob is shaped like a semi ellipse but the key a semi circle (or vice versa).
Could you possibly send us a picture of the oem fob and your printed fob side by side without the key in them? Maybe we could see where there is an issue.
#260
It's always possible, but I kind of doubt it in this case. Everything else seems to be the perfect size.
#262
I too would be super interested in this. I also despise the gigantic fob. It's in my purse most of the time but I still think it's too big! Women pockets are generally smaller than normal so the fob practically takes up my entire pocket when it's not in my purse and I hate it.
#263
this.
#264
How about a couple of small "tech" countersunk (short) chrome screws that would pierce the inside plastic and suck in the flare. The small hole they would make in the center would be covered once the original cover is installed. You could make this part of the "print" or just make them with a small drill and a countersink....
#265
Ok, I ordered another one. This one is a whole mm wider than the last version (which was only widened .3mm).
On the plus side I'm getting to see how a lot of the different plastic options look in person. I would not recommend the high detail plastic for these (too porous), but the base plastic looks great (the green). This time I ordered the base plastic in yellow but polished.
#268
Oh, yeah sorry. It came back. I don't think this design is going to work. There's not enough rigidity to keep the shape when everything is in place :(
The picture makes it look like the fitment is pretty good but IMHO if you're going to sell something it should be a perfect fit or not at all.
![Name: 0m13GfY.jpg
Size: 76.5 KB](https://www.northamericanmotoring.com/forums/attachments/f55-f56-hatch-talk-2014/194210d1683124573-the-new-key-fob-for-the-f56-0m13gfy.jpg)
#269
![](https://i.imgur.com/0m13GfY.jpg?1)
#270
#271
I guess I must be missing something - when the back part of the fob that covers the battery (embossed with MINI) is set back into place, it locks the cover in place, no? This is how I think the factory cover works, so if we can replicate the tabs, this piece should work the same way and get locked in tight?
#272
#273
Looks like you're making a little progress at least.
I still think if you made the top end a little fatter/thicker/wider and then taper down to the keyring end it would help keep it tight.
But, then again, I didn't stay at the Holiday Inn Express, so I'm probably not qualified to make such an observation.
![Grin](https://www.northamericanmotoring.com/forums/images/smilies/grin.gif)
#274
Oh, yeah sorry. It came back. I don't think this design is going to work. There's not enough rigidity to keep the shape when everything is in place :( The picture makes it look like the fitment is pretty good but IMHO if you're going to sell something it should be a perfect fit or not at all.
#275
