F55/F56 Looked into Retrofitting Rear Fogs
#101
Found it, not in head unit.
As I mentioned earlier, its showing coding that is incorrect when reading.
For instance tire temperature with TPMS shows inactive, when is is active. I had it coded by a guy with E-Sys.
Shows DRL in unknown.
Im afraid of what else it reads wrong, and recodes it wrong. I can't look at _every_ parameter.
#102
#103
#105
#106
As I just posted in the coding thread, you need to do the following - not just buying the switch, but also using e-sys to enable the feature in the body domain controller (BDC)
2) 3068, NSL_Verbaut = Verbaut
3)
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_l
3064 Mapping_Nebelschlussl_R_Function = nebelschlusslicht
These options enable the correct outputs on the BDC to activate the lights. You could choose to have only one light on if you wished
3)
3064 Mapping_Nebelschlussl_R_output = nsl_r
#109
Anyone else notice the latest Bimmercode update no longer sees the BDC.
All I get from the developer is the same response overtime I ask a question.
It will be fixed in the next revision. HA!!
EDIT
Due to the new mandatory recode by MINI, Stephan at Bimmercode needs to rewrite his software, as MINI made it harder to access.
EDIT
EDIT
EDIT
#110
EDIT
EDIT
EDIT
EDIT
#111
#112
Can you repost that a bit bigger, i cannot see all of it. Thanks for posting that up.
TVPostSound (09-18-2017)
#114
12-23-2015 10:36 AM
dyeLucky
08-07-2015 07:10 AM
