F55/F56 Locking with audible
Old 09-03-2014 | 11:44 AM
sal1k's Avatar
sal1k
Even more difficult for some now...
Check out this other thread I started:
https://www.northamericanmotoring.co...d-working.html
Now even lights don't seem to flash anymore for me when locking the car.
  #27
Old 09-03-2014 | 12:01 PM
MINIwuff's Avatar
MINIwuff
Originally Posted by hammerhands
Page 43 of the manual says...
So it should be there, if it's available.
Audible lock and unlock is not an option for vehicles without the factory alarm system regardless of what the manual states. The manual is designed to incorporate all F56 models and all options regardless if equipped (think "your model may vary", scenario).
If you actually go into the settings menu of your vehicle, you will see that the "audible setting" is not an option or even listed.
  #28
Old 09-03-2014 | 01:20 PM
CobraBob's Avatar
CobraBob
I totally understand about the "your model may vary" thing, but God forbid that they would actually simply add a notation that the feature is only available on vehicles equipped with the optional alarm system. And avoid unnecessary confusion. And add a simple notation in the Configurator that the alarm feature adds an audible beep when locking your Mini. As much as I love Mini, they really fail too often with documentation and customer communication.
  #29
Old 09-03-2014 | 02:16 PM
George 2014's Avatar
George 2014
Getting back to the audible-beep thing, it would not be difficult at all to just install a stand-alone horn, then trigger it via a relay from whatever circuit it is that flashes the lights when you lock the car via the keyfob.
  #30
Old 09-03-2014 | 02:31 PM
Mrdi's Avatar
Mrdi
Good idea,
A relay and a 150 db air horn should do the trick.
Perhaps a phrase from "I'm an Okie from Muskogee", blasting from an external speaker.
Better yet, an air suspension installation so it can bounce up
and down while tooting.
  #31
Old 09-03-2014 | 04:20 PM
hammerhands's Avatar
hammerhands
All my knowledge is theoretical.
JamesDeBart
04-16-2016 06:00 PM
gnhovis
12-14-2015 06:31 PM
R3411y
11-23-2015 02:10 PM
vulkandino
10-31-2015 09:29 PM
Island maser
General Discussion
10-01-2015 02:09 PM
