F55/F56 Mini coding/programming
#351
Same here -- finished coding this morning... everything works! Thanks to everyone!
#352
need some help guys,
could someone help getting into Comfort FSC, and check FSC status to see if there is Appid260(0104) there? thanks a lot.
DME_BAC[DiagAddress=18(0x12)]
WMWXM710XXXXXXXXXX
RootCertStatus not available
SWSigStatus accepted
SWTApplications
AppID 192(0xC0)
UpgradeIndex 1(0x01)
SWTType SWTclassic light
FSCStatus not available
FSCCertStatus not available
AppID 157(0x9D)
WMWXM710XXXXXXXXXX
SWTApplications
AppID 192(0xC0)
AppID 157(0x9D)
#353
I've been through this whole thread and have a list of what I want changed:
Play ringtone from phone
With auto lock enabled, all doors unlock with ignition shutoff
A/C System Remembers Last Setting
Turn off radio/nav when opening drivers door
I also have a wish list:
Add profile A2DP to play music via BT?
Stop asking if I want to configure green mode every time I activate it.
Is there someone in Los Angeles who can help me with this? Please PM me.
#354
Switching driving modes will still change the light ring (if you have it configured that way under Center Instrument), but you won't get the popup about configuring every time you switch it.
#355
This one you can fix on your own. Go to Settings --> Driving Modes --> and turn off Driving mode info.
#356
#358
I'm assuming pjo1966 has base radio, because they're also asking about enabling an A2DP profile for bluetooth so that they could play music via BT, which isn't enabled with the base radio.
I know this, of course, because I have Base Radio, and would also very much like to enable A2DP
#359
- Paul
#360
There's a way to add A2DP on BMW base radios, so I can only assume there is a similar process for F56s.
As for your driving mode configuration pop up....There's a way to disable it on the Visual Boost and XL headunits, I'm actually surprised the base radio doesn't have that same option...
#361
Ive done a lot of programming to my S.. now looking at the JCW Tuning Kit does anyone know if I will loose my coding(and future coding) doing the flash to the ECU.
#362
#363
on
Any coders able to help me???
I have fitted the bumper from the John Cooper Works to my Cooper S.
As people will know... the bumper is different in so much as the fog light assembly (which also contains the sidelights) is deleted and replaced with honeycomb grilles
The headlights on my car are LED headlights with an incorporated DRL LED 'horseshoe' ring. This headlight is also stock on the JCW car however, unlike the Cooper S it uses this DRL ring as its sidelights instead of the separate unit in the lower bumper like on the Cooper S.
Anyway without complicating things any further...currently this is the sequence associated with the headlight switch on the car as it stands:
1) headlight position switched to 'off' = LED DRL in headlight ON / rear lights OFF
2) headlight position switched to 'sidelight' = LED DRL in headlight OFF / LED sidelight in bumper ON / rear lights ON
3) headlight position switched to 'on' = LED DRL in headlight ON [with reduced brightness] / LED sidelight in bumper ON / LED dipped beam ON / rear lights ON
What I want to happen is for the car to replicate the JCW in terms of lighting which would be:
2) headlight position switched to 'sidelight' = LED DRL in headlight ON / rear lights ON
So in basic terms, I want my car to use the LED DRL's [which are built into the headlight] as the side lights, since my Cooper S will no longer have the fogs / sidelights in the lower bumper...
Can anyone shed any light on this?
#364
Available Coder in Cleveland Ohio area?
Good evening Ladies and gentleman,
I am very new to this forum. I just found it and love it already.
I am a semi new MINI owner and looking to code/program my car.
My first MINI was a R60 JCW - I recently traded it for a 15 F55.
The five door is amazing - Love it! I am looking for someone I can have program/code my car for Video while in motion, roll up windows with fob, fogs with high beams and iPhone ringer.
If anyone can help I would be forever grateful. Let me know.
Thank you everyone and Have a wonderful evening.
#365
#366
I think somebody already tried changing the VO long time ago and failed.
I didn't try because I'm thinking the base radio doesn't have the necessary software (there's nothing in the menu where you can select Bluetooth stream). So even though the hardware is there, the software is not ready for it and will probably never be, unless MINI changes something or you shell out $500 for the visual upgrade. It's pretty stupid that they don't include Bluetooth streaming in stock configuration in this age. I just use a Sandisk micro USB flash drive which sticks out less than 5mm.
#368
Hey
I am very new to all this and i have the alast days read and look and so on, my frind have a BMW F10 2011 and would like to have few things unlock. and i have today download the BMW PSdZData full 3.55.0.100 but have now seen that i cannot use this
because there is missing the CAFD FILES, can i now delete this download and fin another one
Or can somebody help me if i really need the CAFD files. few other says that you download them from the car inside the E-sys.
#369
Hey
Keep that download and get the CAFD files from the last "Lite" version.
#370
Hello
Thank you so much, do you have a link for lite files, because i dont find it on the forum when i use the search buttom and i dont hope i need to download 30 gb too
P.S what for a cabel is best
http://www.ebay.de/itm/1-BMW-RJ45-EN...item3390550843
or
http://www.ebay.de/itm/MaxDia-ENET-E...item338aedcd8a
or
#372
Hello
I need you help one more time and i hope it is okay, we have today testet the E-sys and it works 100% but we could not find these one, becase we was not sure what to look for.
Could somebody help us.
Reverse mirrros tilt down.
Standlight that is full power as when you havefull light on.
#373
#374
or
or
I haven't tested this one, but mine looks even crappier than the $5 one I linked. I posted it somewhere in page 3 or somewhere. It works fine. They don't have any special chip or anything so there's no reason to be expensive.
I actually wanted to lower the voltage hoping it'll make it last longer, but didn't see any difference. The headlight is way brighter than I need it to be. I have a LED headlight by the way.
#375
WMWXM710XXXXXXXXXX
SWTApplications
AppID 192(0xC0)
AppID 157(0x9D)
WMWXM710XXXXXXXXXX
SWTApplications
AppID 192(0xC0)
AppID 157(0x9D)
