F55/F56 Mini coding/programming
#801
#802
Hmm, actually, I found something more here: http://www.2addicts.com/forums/showthread.php?t=1231483
I wonder if our cars have C_Funktion_Differenzialsperre_aktiv_l. I'll have to dust off my windows laptop and take a look to see if it's in the coding tool.
--Matt
--Matt
I spotted C_Funktion_CorneringBrakeControl_aktiv_I there too, which sounds enticing. Brake intervention in turns has always bugged me too.
--Matt
#803
My car does have that setting, and it was set to aktiv. I flipped it to nicht_aktiv. My kid's asleep and wife's away, so we'll see tomorrow what that does. It was midly disconcerting during the FDL coding when every possible DSC-related indicator popped up, but they all went away after. I wonder if the challenge car ships with this setting disabled too.
--Matt
--Matt
--Matt
toyopet (03-01-2018)
#804
#805
--Matt
#806
That's great, exactly what I want to get, they are about $1,065 now (https://www.ecstuning.com/b-wavetrac...6309191wk~wvt/) and I'm sure I could find someone to install it for less than $1,200 - I'll start saving for this very soon.
#808
--Matt
#809
#810
Yes yes yes! This is exactly what I wanted. I drove through heavy rain on my way to work and, no matter how much gas I used, never saw a blinking light once in a straight line. All I saw was perfectly managed traction. The blinky light still came on when attempting WOT in a turn, thanks to stability control, which is how I like it.
--Matt
--Matt
I didn't see DSC in Bimmercode but did find it using E-Sys
#811
#812
In your BimmerCode app, does the option to disable the seatbelt chimes/warnings appear? I had it coded, flashed my ECU, tried to code that in the app and the option was gone now.
The shortcut goes to ASM_4i but the seatbelts are ASM_2. Its the last thing I want to change, dang it!
#813
#814
#815
#816
^Crap, spoke too soon, I just checked and it's going to be exactly $1,200 for the lsd install...I'll start saving, I must have that.
#817
Mini_Vinnie (03-01-2018)
#818
#820
EDIT - It's back!
#822
#823
No, which is incredibly frustrating. The only reason I knew to look for it was because a fellow user mentioned the app creator was working on adding the seatbelt option back
#824
