F55/F56 Mini coding/programming
#126
When I set ESS_AKTIVIERBARER_AUSGANG to "bremslicht blinkend" it does indeed pulse the brake lights during heavy braking, but then I get a "lighting system malfunction" warning. This doesn't happen when I switch it back to the default of "flachenvergroesserung".
Anyone else having this issue?
#128
I think it'll work fine. It's a basic wiring harness with one 500 Ohm resistor in it. I thought of building it myself, but then I can't beat the $5 price. Oh, and the one I ordered is not a regular ODB2 reader, it's actually a ODB to ENET for use with e-sys.
I don't think there's a normal ODB2 reader with an Ethernet for reading ODB2 codes. I've seen bluetooth, wifi, serial ports, USB, but not Ethernet ones.
This is what I bought. It's actually $5 not $4. lol.
#129
I just received the $5 ODB to Enet adapter in mail today. It works fine.
Am I doing something wrong here? Attached my screen capture.
* Disable seat belt disconnected reminder sounds
ACSM
3001 - SBR_PreWarning_Fahrer = Set Nicht Aktiv (front driver)
3001 - SBR_PreWarning_Beifahrer = Set Nicht Aktiv (front passenger)
ACSM
#131
ACSM
ACSM
You can also put the function in the "search for" bar and look for it that way.
#132
Awesome. Thanks! I was reading the instructions from my phone and couldn't see much in short time. I was thinking do I have a different software or what? lol.
Do you guys keep your engines on while coding, or just ACC on? I'm wondering if ACC on uses much electricity. I have a bad memory where my Saab 9-5 battery went dead after 10 minutes of ACC on mode without starting the car.
#133
#135
If I'm doing a quick coding change that's less than 5 min I'll use ACC, otherwise I'll keep the car running.
Important that if you're using the full version of PSdZData and are temped to update your ECUs, do NOT do this without being hooked up to a good, stable external power supply. I've seen reports of people bricking ECUs while trying to update just with the car running.
Not that for simple coding, this isn't an issue.
#136
I looked up on AGM battery charge methods, and it looks like the only difference is how the float charge should be done (should be done at lower voltage). AGM can actually take higher charge voltage than regular lead-acid battery. I'm not doing float charge so I think it's okay with my Black & Decker 25 amp charger . I see on a kill-a-watt, it typically uses 60-100W when charging a battery that has about 70% charge.
edit: Okay. I hooked the charger, and put ignition in ACC on. Then started coding again.
All I got done is the door handle light when in reverse. BDC 3070 - OVT_BEI_REUCKFAHRLICHT = Aktiv
edit2: I tried modifying "side mirror tilting down on reverse" - BDC 3110 - ASP_BORDSTEINAUTOMATIK_DELTA (werte=4B. was 55). I don't think it changed anything. To do the "side mirror tilting downwards on reverse" do I need the automatic folding mirrors?
#137
Anyone tried these? These are locations from F56. I programmed mine but didn't test yet.
IHKA Module:
A/C System Remembers Last Setting
3003: MEMORY_OFF set to aktiv-werte=01 *default was nicht_aktiv-werte=00
Always Remember Air ReCirculating
3003: MEMORY_UMLUFT aktiv *default was aktiv so didn't change anything
ACSM Module:
Seatbelt reminder durantion
3001: GWF_SBR_WARNDAUER (werde = 01 for 1 sec) *default 5A (=90seconds)
Does "nicht_aktiv" and "werte=00" always go together? So if I want to change them, am I supposed to change both to "aktiv" and "werte=01"?
IHKA Module:
ACSM Module:
#138
Anyone tried these? These are locations from F56. I programmed mine but didn't test yet. IHKA Module: A/C System Remembers Last Setting 3003: MEMORY_OFF set to aktiv-werte=01 *default was nicht_aktiv-werte=00 Always Remember Air ReCirculating 3003: MEMORY_UMLUFT aktiv *default was aktiv so didn't change anything ACSM Module: Seatbelt reminder durantion 3001: GWF_SBR_WARNDAUER (werde = 01 for 1 sec) *default 5A (=90seconds) Does "nicht_aktiv" and "werte=00" always go together? So if I want to change them, am I supposed to change both to "aktiv" and "werte=01"?
#139
"Werte" means value. These change when you edit the setting via the drop-down (i.e. from nicht_aktiv to aktiv). Selecting aktiv will always change the value to 1. No need to modify the value as well.
The exceptions are things like enabling video playback in motion- you need to set the value to something outside of that would normally be done.
#141
Code:
Automatic Curb Monitor When the reverse gear is engaged, the mirror glass tilts downward slightly on the front pas‐ senger side. This improves your view of the curb and other low-lying obstacles when park‐ing, for example. Activating 1. Slide the mirror changeover switch to the driver's side mirror position. 2. Engage transmission position R. Deactivating Slide the mirror changeover switch to the pas‐ senger side mirror position.
#142
I couldn't get this one to work. My auto climate control defaulted to off every time and I couldn't turn the fan off in any mode. Also, when on auto, the A/C light would blink sometimes. It was very strange so I set it back to original. I decided too that I like the auto climate to come on by default when I start the car.
#143
#145
So, after changing the MEMORY_OFF option, my car no longer starts with AUTO mode which was kind of annoying that I had to turn it off every time.
Tilting the side mirror on reverse still didn't work even with the mirror selection set to the driver side, so I just changed it back to default value 55.
Anyone know what turning off ECO_TIPPS might do (in screen capture)?
This is in IHKA module 3001. I don't have the Visual Display upgrade so no fish. What kind of tips am I receiving from eco mode with basic radio?
Looking under IHKA module 3003 there's "AC_ON_WITH_AUTO" which is set to AKTIV. I'm going to disable it so AC doesn't kick in by itself when I select AUTO. I want to be in control of the AC to prevent AC smell.
#146
I have no clue what the eco_tipps is, if I were to guess it has to do with green mode
#147
I don't believe you need power fold mirrors for this, however, the power mirror button in the car must be set to the left (driver) for this to work. From the owners manual:
Code:
ASP_BORDSTEINAUTOMATIK_DELTA sets the angle the mirror tilts when in reverse.
#148
Related to the auto climate control, from looking at "AC_ON_WITH_AUTO", I think if the temperature is hot enough the AC will turn on automatically (unless you disable this one) when you have AUTO climate turned on.
--edit: this didn't work. Requires special hardware (called Mirror Memory which is probably an option in Folding Mirrors).
I created a public editable GoogleDoc excel sheet just for my car (F56 base/automatic). But in case anyone wants to peek at it, or edit, or copy it, here it is. I wish there was a Wiki page in this thread where everyone can just edit it. Or maybe the thread starter can make a new one and edit his first post so everyone can just edit it through there.
#150
