F55/F56 Installing Dash Cam - Electrical Question
I've purchased a dash cam and it came with an electrical hookup. Unfortunately, I have no idea where to install it or even how. Was hoping someone could help me with it. I've attached a picture of the hookup. Is there anyway to hook this up to the fuse box? If so, how would one go about doing that. Again, I've never done this before so detailed instructions would be much appreciated.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
this is sometimes called an "add a circuit" and should run less than $10 at any decent auto part store
it is an easy way to add a low power item to your fuse panel; your device would appear to qualify ... your red wire (hot) connects here. The black wire goes to a ground ... all you really need is a metal screw that goes into metal .... look around near the fuse panel ... they are there ... loosen and attach the ground wire.
done
done
Drivetrain Belt system whine after oil cooler install
whrisk
10-31-2015 08:54 AM
MiteyF
10-19-2015 01:31 PM
MiteyF
10-18-2015 09:28 AM
