F55/F56 Leaking fluid from rear view mirror/rain sensor
Old 12-27-2015 | 03:58 PM
Skummdogg's Avatar
Skummdogg
Found this today on my 2015 mcs. It has been in the mid to high twenties for the past couple days. Car has been parked outside. It's a clear liquid, semi oily. Couldn't smell anything due to the current cold I'm having. Any ideas what and where it's coming from? This is the best picture I could take, you can see it if you look.
<a href="http://s31.photobucket.com/user/skummdogg/media/Mobile%20Uploads/DB3FEF1C-0FB1-4640-8F4A-6E3AACE3EBBF.jpg.html" target="_blank"><img src="http://i31.photobucket.com/albums/c396/skummdogg/Mobile%20Uploads/DB3FEF1C-0FB1-4640-8F4A-6E3AACE3EBBF.jpg" border="0" alt=" photo DB3FEF1C-0FB1-4640-8F4A-6E3AACE3EBBF.jpg"/></a>
Thanks, Charlie
Old 12-27-2015 | 08:00 PM
MasterYoda's Avatar
MasterYoda
Someone in another post mentioned it's a gel pack for the rain sensor, whatever that means.
Take it in and your warranty will cover it. I had the same issue.
Old 12-27-2015 | 11:07 PM
hp79's Avatar
hp79
Yeah, it's the rain sensor gel pack. I don't know why they can't get this right. I replaced mine for the second time, and I doubt it's a permanent fix. The second time I replaced it, it wasn't even parked under the sun, the car was barely driven mostly parked in a 15-20C garage.
The dealer was very nice to replace the part and provide a loaner though.
Old 12-28-2015 | 12:53 AM
Skummdogg's Avatar
Skummdogg
Thanks guys. You said you weren't parked in the sun... Is that what they are claiming causes it? It's been below freezing here. I'd say heat isn't the issue
Old 12-28-2015 | 12:22 PM
Yes, more info here :
https://www.northamericanmotoring.co...ew-mirror.html
Old 12-29-2015 | 03:07 PM
carman63's Avatar
carman63
What they said. I'm on my 4th one. I was told back in June/July that MINI was working on a fix, and I was put on a list to get it. Just replaced it again a month or so ago.
Old 12-29-2015 | 03:37 PM
hp79's Avatar
hp79
Can't believe how they can't find a fix for this. Does anyone know if there's a problem if there's air bubbles inside the rainsensor where the gel pack leaked out from?
Old 01-12-2016 | 02:07 PM
ChgoMini's Avatar
ChgoMini
Originally Posted by hp79
Can't believe how they can't find a fix for this....
I can't either. This has been going on since launch. I guess Mini has done the math and figured it's cheaper to inconvenience the owners and replace these gel packs as they fail instead of creating a fix.
Old 01-12-2016 | 02:30 PM
Do you have pics of the leak on the sensor and behind it ?
Old 01-12-2016 | 03:23 PM
ChgoMini's Avatar
ChgoMini
Pics and the part number are found in this thread and its associated links.
Old 01-12-2016 | 03:39 PM
Yea, See that one above, need to see the front side on the window and a close up of that gel packet.
Old 01-12-2016 | 04:18 PM
hp79's Avatar
hp79
I remember taking a photo from the outside of the windshield about the gel leaking and air bubbles trapped inside the sensor but I don't know what I did with those photos. I might have deleted them after getting it serviced. I'll see if I can take a photo of it again when I have time. Mine has been replaced second time and it hasn't leaked again yet but I see there's air bubble trapped inside the sensor.
Just a thought, but maybe it leaks more easily if there's any air inside which might expand and shrink depending on the temperature.
Old 01-13-2016 | 07:15 AM
That's what i am thinking, air bubbles no good.
Old 05-17-2016 | 03:23 AM
remotecontrol's Avatar
remotecontrol
i have mine windshield replaced and since then my rain sensor not working due to bubbles... i have researched all over the net, try many methods and finally i succeeded by just sticking the sensor using clear silicone. no bubbles! now it works like new however the only worry is would it stand the heat under the sun with 70C+ inside the car...
oskai
R57 :: Cabrio Talk (2009+)
01-06-2016 09:45 AM
spenrue
12-23-2015 10:24 AM
12-23-2015 09:51 AM
MikeMiniS
12-22-2015 07:18 AM
PelicanParts.com
Accessory Products
12-21-2015 02:15 PM
Quick Reply: F55/F56 Leaking fluid from rear view mirror/rain sensor
