F55/F56 Dyno numbers for f55 with NM Engineering Powe Module + k&n typhoon
Old 04-01-2016, 05:14 AM
FastMiniS's Avatar
FastMiniS
FastMiniS is offline
Originally Posted by vetsvette
No issues whatsoever. You don't even know it's there until you put your foot in it. To me it has a more consistent linear feel to the power band. I'm re-installing mine this afternoon at the same time I install my brand spankin' new AWE intake. I removed the module and ran the car with only the JCW tune during the break-in of my new motor.
I would recommend it without reservation.
Thanks! I'm going to go ahead and order one. I like that it is very easy to install/remove.
Can you post a photo of your AWE intake when it's installed?
  #27
Old 04-01-2016, 07:58 AM
Mazarin's Avatar
Mazarin
Mazarin is offline
I put mine back in yesterday. The sound is louder, more BOV, and POWAAARRRRRRRRRRR.
I love it.
  #28
Old 08-04-2016, 11:57 PM
Joespeed's Avatar
Joespeed
Joespeed is offline
sorry to revive an old tread.. but figured this was better than asking a related question..
if I read the posts correctly,
NM on high with pump gas 93/91 (whatevers avail in your area) will not yield better results necessarily because of timing?
NM on High with 100 oct is will yield higher results as stated?
I'm looking to add exhaust next.. and hopefully find a dyno day around here so I can put the NM Mod on high with 100 oct and get a few pulls in
  #29
Old 08-05-2016, 06:58 AM
USA-RET's Avatar
USA-RET
USA-RET is offline
Yes, that pretty much sums it up.
I've not seen any dyno results w/ NM set to high w/ 100 octane gas.
Would be interesting to see what a stock MCS w/ 100 octane and NM set high would produce.....and another result w/ MCS w/ a JCW tune and the NM set to high w/ 100 octane.
Now those numbers would be interesting to peruse. Got to think it would be putting close to 300HP (providing the ECU doesn't start dialing back).
  #30
Old 08-08-2016, 06:48 AM
BellaF56's Avatar
BellaF56
BellaF56 is offline
MidwayMountaineer
06-27-2022 07:39 AM
-=gRaY rAvEn=-
06-02-2016 02:22 PM
scubus
03-11-2016 01:16 PM
Helix13mini
03-11-2016 12:52 PM
Quick Reply: F55/F56 Dyno numbers for f55 with NM Engineering Powe Module + k&n typhoon
