F55/F56 Calling all autox/track guys
#26
I really would be surprised if there is improvement to be had with a BBK on the chassis at the weight and power it's at. There's always room for improvement with ABS deletes, removing boosters, proper track temp pads. I could see in a spec challenge doing extremely lightweight calipers and rotors - but I don't think it needs that big braking surface at the weight it's at. I'm guessing you can put a LOT of power in before you'd have temperature issues from overall heat too.
If we were looking at like a 3500lb race weight I'd see it. The Mini is closer to 2900 though isn't it?
yep, just not as good of a track tire selection and more expensive with the 18s.
#27
Yup, most BBKs I think people do for the looks more than anything. Which is totally fine - they also provide an interesting feel on the street that can be pretty confident and nice. If you're really going full on track route, my guess is it would be better to stay with 16s, use the gearing from it, and try to get some sort of ducting in to the barkes.
For AutoX, I'd try to keep to 15 even. At that weight, you don't need much tire and you don't need much brake, but lightness always helps.
#28
I am no expert but AX seems to be all about better traction and getting as wide of a tire as possible. To my I would think going to 18 and getting a wider tire with a little extra weight would be better than narrower lighter setup. Then again I am still a newb at AX.
#29
Interesting and I probably should post in a separate thread as we are high jacking randomquickness' thread.
AutoX can go either way - I haven't done it with the Mini, sometimes going too low will make you top out 2nd and have to go between 2/3 too much and cost you time. It's always an experiment, sometimes you need to change it for different courses even.
Lighter always wins though, and all other things being equal, a 15x8 will always be lighter than a 17x8 or 18x8.
BABY J
04-23-2016 06:16 PM
tylerc
04-19-2016 01:01 PM
USA-RET
04-18-2016 08:16 PM
