F55/F56 NM boost tap/Gauge
Old 06-07-2016, 12:32 AM
Ti DeZod's Avatar
Ti DeZod
Ti DeZod is offline
NM boost tap/Gauge
Hey y'all!
So I ordered the nm boost tap and a gauge to install in the mini. Anyone got some good recommendations on where to run the hose??? Plus I'm thinking about modding one of the A/C vents to hold the gauge... But looking at the dash, it's gonna be harder then I expected to access the vents. If someone can give me some insight that would be great!
Old 06-07-2016, 12:44 PM
MarcoPolo's Avatar
MarcoPolo
MarcoPolo is offline
You're better off just getting the gauge pods from cravenspeed. Much easier. As for running, I went along the front just underneath the engine cover then under the intake, made a small hole into the battery space and then ran it into the car using the clutch cable grommet hole. It's the same hole used to run the burger tuning jb4.
Note, be sure to lightly grease all the o-rings as well as when the hose attaches to the tap. I had a boost leak the first time.
I'll put up a picture of mine but if you look for me on Instagram (minif56nyc) you'll see how it turned out. Good luck!
Old 06-07-2016, 01:03 PM
Ti DeZod's Avatar
Ti DeZod
Ti DeZod is offline
Thank you marcopolo!!!!
Thanks so much for your reply!!!! Hey would it be to much for u to post some pics of where you ran the line and of the gauge pod???lol basically your set up! What kind of grease did u use? Silicon? And what exactly did u grease? Thank you tons for your help Marco Polo! I need as much help as I can!
Old 06-07-2016, 02:12 PM
GregoryK's Avatar
GregoryK
GregoryK is offline
Originally Posted by Ti DeZod
Hey y'all!
I used a AEM boost gauge do it could be metric. The tube on that is short do I just ran weird from the sensor. I also bought my tap from China for $6.50 looks and works perfectly.
Old 06-07-2016, 05:38 PM
Ti DeZod's Avatar
Ti DeZod
Ti DeZod is offline
Pictures??
Old 06-07-2016, 05:58 PM
GregoryK's Avatar
GregoryK
GregoryK is offline
Pictures??
Of what? I penetrated the fire wall at the gasket on the right side of the battery.
Old 06-07-2016, 06:01 PM
Ti DeZod's Avatar
Ti DeZod
Ti DeZod is offline
How did you mount it?
Old 06-07-2016, 06:15 PM
MarcoPolo's Avatar
MarcoPolo
Old 06-07-2016, 06:45 PM
Ti DeZod's Avatar
Ti DeZod
Ti DeZod is offline
That's awesome dude! I see your in New York! I'm in Fl but from queens. I'm ordering the pod right now from crave speed. I am also installing pss10, rear adjustable control linkages, and that's it for now besides the boost gauge! Thanks for you pic it looks clean af
Old 06-08-2016, 04:41 AM
GregoryK's Avatar
GregoryK
GregoryK is offline
Marco. What gauges are those?
Old 06-08-2016, 06:09 PM
MarcoPolo's Avatar
MarcoPolo
Old 06-10-2016, 09:48 AM
Ti DeZod's Avatar
Ti DeZod
Ti DeZod is offline
So I got the craven speed gauge holder... How did you instal???
Old 06-10-2016, 10:39 AM
CravenSpeed's Avatar
CravenSpeed
CravenSpeed is offline
Vendor
Got you covered, instructions are here.
Thanks for your order!
-=Kellen
Old 06-12-2016, 07:44 AM
GregoryK's Avatar
GregoryK
GregoryK is offline
Marco. What is the lowest negative boost (vacuum) do you get? I read somewhere that you should see -18 but I'm only getting -4.
Old 06-12-2016, 09:06 AM
Ti DeZod's Avatar
Ti DeZod
Ti DeZod is offline
Thanks looks great!!! My boost tap from nm is delayed ��������
Old 06-13-2016, 07:33 AM
MarcoPolo's Avatar
MarcoPolo
lowest i've ever see was 1 bar, which would be -2. what's been your peak? i forget if you're on an NM Module or JB4 or stock.
Old 06-13-2016, 10:27 AM
GregoryK's Avatar
GregoryK
GregoryK is offline
I'm installing many updated JB4 unit this weekend....! I can not wait!
Stock I get +17 under the hardest acceleration.
Old 10-23-2016, 07:01 PM
toyopet's Avatar
toyopet
toyopet is offline
Can someone explain why the B48 only shows about -4 in.Hg of vacuum at idle? I see that in Marco's boost/vac gauge, too.
Old 10-23-2016, 07:08 PM
MarcoPolo's Avatar
MarcoPolo
i don't know. at first i thought i had a leak but given that 3 of us are reading values of -4 it must be normal........or we all screwed up
for the record, my tap itself is the NM Brand.
Old 10-24-2016, 06:16 AM
trentiles's Avatar
trentiles
trentiles is offline
The F56 does not really make any vacuum in the intake manifold which is where you are getting your readings from. I believe the N18 engines from the R5x gen are the same way.
Old 10-24-2016, 08:06 AM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
Don't know about the B46/48, but I do know my '07 with the N14 pulled enough vacuum to activate my forge blowoff/diverter valve. Don't have a clue what the threshold was for that though. Could have just been anything less than boost. All I know is it worked like a champ.
Old 10-25-2016, 05:57 AM
trentiles's Avatar
trentiles
N14 actually had vacuum in the intake mani. N18 and up do not.
Old 10-25-2016, 11:58 AM
Loccusst's Avatar
Loccusst
Loccusst is offline
So is there a better place to tap to get an accurate reading?
Old 10-25-2016, 12:24 PM
GregoryK's Avatar
GregoryK
GregoryK is offline
Mine gives an accurate reading. Well, same as my JB4. So I assume it's correct.
Old 10-25-2016, 04:42 PM
trentiles's Avatar
trentiles
The intake manifold taps are fine, they just only show positive boost, not vacuum.
Quick Reply: F55/F56 NM boost tap/Gauge
