F55/F56 Coding parameters that actually work using Bimmercode Expert Mode
Coding I tested today using Bimmercode Expert Mode:
Add as you wish, but only tested and working functions.
Activate Rear Fog Lights:
3068 NSL_Verbaut = Verbaut
Code first, the cycle ignition, then restart Bimmercode for the below options
to show up
Activate Rear Fog Lights feature for lighting switch:
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht
Every time you recode after doing rear fogs, you WILL get a dash warning about lighting errors.
cycle the ignition, it will go away, the warning after coding is because the VO has not been coded.
It will not persist after that.
Close windows, sunroof & mirror from key fob:
3056 KOMFORTSCHLIESSUNG_FB = aktiv 00
Turn off window roll-up door interrupt when ignition off, and door is being opened:
3050 FH_TUERAUF_STOP_MAUT =aktiv
Disable Active Sound Design
3000 ASD_SOUND_OFF = aktiv
Display Tire Pressure & Temperaure in Vehicle Info:
3001 RDC_SAFETY = aktiv
Fogs on with high beams
3068 NSW_AUS_BEI_FL = nicht aktiv (AUS means off + nicht aktiv is a double negative = ON, so nicht aktiv)
Fogs on with DRL/Parking lamps
3068 NSW_EIN_AUF_LDS_STL =Activ (EIN_ AUF means To go on)
Enable Illumination of Exterior Door Handle LEDs when in Reverse
3070 OVT_BEI_REUCKFAHRLICHT = aktiv
Installed LED reverse lights:
Turn off warm and cold monitoring
Turn on LED status
Rückfahrscheinwerfer = Reverse lamps. RFS
3061 RFS_L_KALTUEBERWACHUNG = nicht aktiv
3061 RFS_L_WARMUEBERWACHUNG = nicht aktiv
3061 RFS_L_IS_LED = aktiv
3061 RFS_L_IS_LED aktiv
Tip blinker stalk for 5 blinks instead of 3.
3069 PIA_DEFAULT_TIPPBLINKEN =FUENFMAL
to show up
Turn on LED status
BDC Module
3068 NSW_AUS_BEI_FL nicht aktiv
It translates to fog lights OFF with high beams (default is aktiv)
So you double negative the response to leave on.
But it won't do what the R56 did after coding which is turn off fog during high beam pull to pass.
I miss that. So it would look like youre flashing the high beam alternating with the fog when doing an Autobahn
flash.
flash.
vetsvette (09-17-2017)
This version of Bimmercode is missing a bunch of settings as compared to the website.
Those settings are basically scripts or shortcuts pointing to expert mode.
Expert mode scans all the modules, so everything that can be done
with ESys and a laptop can be done with Bimmercode.
The only things that can not be done is VO additions, GPS maps and
Sirius XM coding.
Sirius XM coding.
Just curious on the tire pressure and temp display. I have a 2011 mcs that had the boosted CD Harmon kardon system in it. I retrofitted oem nav and mini connect in the car and when I go into vehicle info it shows the the car and that tire pressure is "ok" so if coded it should show the pressure and temp?
R series did not report tire pressures.
Just got Bimmercode and the wifi adapter.
Seems like I am having some luck with certain changes, but not others.
One that doesn't work is setting lane change indicators from 3 to 5. It just always blinks 3 times. Has anyone gotten this to work?
Also one strange thing, when I got into the ASD menu and then Export - Model it says my model is F022 and not F055 like I have. Can someone verify this setting on their car? I was a bit hesitant to change it to F55 even though that is the model I have.
I changed the model back to F055 but it seems like ASD is still off, I am trying to get it back on.
Going to see if I can do a restore of the ASD module using Carly backup and see if that fixes things.
