F55/F56 What do you use to clean wheel arch trim?
Hi everyone. What product do you use to clean the black plastic wheel/fender trim? Over the last almost 3 years mine have started looking dirty and have white streaks. It's not like Jeep Wrangler fender flare gray fading yet, but you can see soap and wax residue. How can I clean the trim thoroughly without fading them from black to gray?
Thanks!
Thanks!
Thanks!
Thanks!
Clutch Wotan (09-21-2019)
I’ve been using Black Wow for the past three years. It’s been better and longer lasting than other products I’ve used. I recently bought PreWow to clean and prep the plastic. It has helped tremendously in keeping my flares black and clean for much longer than just the Black Wow alone.
Black Wow is the stuff. Go visit the old "Detailing 101" section, everything you need to know resides therein. Richard Lin shared a lot of wisdom,
https://www.blackwow.com/
https://www.showcardetailing.com/
Thanks everyone! I hope to take a few hours to attack the trim this coming week or weekend. I had to use some actual black dye to fix the trim under the windshield that had actually gone gray/nearly white. I glad the fender trim isn't that bad yet and will hopefully prevent more damage by cleaning and treating them.
Chemical guys VRP.
If you're looking for a multi-year solution I would recommend looking into AMMO NYC Frame Pro Trim Coat
- Easy to apply! Going on two years since the first application and the trim looks better than new
https://ammonyc.com/products/ammo-frame-pro-trim-coat
Before applying you need to degrease the wheel arch trim with dish soap or their Brute Wheel soap
https://ammonyc.com/products/ammo-brute-wheel-soap
Hope this helps and motor on -Rich
Interior/Exterior Polish on black plastic trim - please help
Dan_C
09-16-2003 01:42 PM
