R55 Incandescent headlamp bulbs?
Hi folks. I installed new 9003 bulbs from NAPA in my wife’s F55. I love the color temperature, but not the headlights barely throw any light on the road on low beam. High beam illumination is normal. Premium headlight bulbs cost more than pocket change, and I want to make the right choice next time. My experience with S. Silverstar bulbs has been fair, with excellent light quality, but short bulb life. I purchased the NAPA product for the three-year unconditional warranty.
Does anyone have any recommendations for a longer-life premium Halogen bulb? Is there a reputable manufacturer of a hassle-free plug-and-play LED 9003 replacement? Will I have to go back to OEM?
cheers.
cheers.
I've had good luck with Philips X-Treme bulbs - about the same as Sylvania but a much longer life.
I buy them here: https://store.candlepower.com/h4hb29003bulbs.html
I'm tempted to try the Vosla H4 next time I need bulbs.
You might also check the alignment - bring the low beam up just a little bit.
conewrench (02-27-2020)
You're correct - decent quality bulbs will have the filament in the correct place - headlight alignment should not be affected.
You don't really need a headlight adjustment gauge. On the back of each headlight, you'll see two largish screws; one is for left/right adjustment & one for up/down.
Just point the car at a garage door or brick wall about 25' away & make sure the 2 low beam patterns are level with each other.
Then adjust the up/down screws on both UP a small amount - one brick.
Engineer or not, you might be interested in this! http://candlepowerinc.com/pdfs/H4_9003.pdf
conewrench (03-05-2020)
MiniKar
01-20-2018 10:21 AM
R50/53 Xenon Head Light Replacement
RPhil40342
01-13-2017 07:43 AM
R50/53 Xenon and halogen headlights
wvmtnbiker
11-13-2013 06:18 PM
