F55/F56 Remus Exhaust Questions
Hello everyone. I'm looking to upgrade the exhaust of my 2019 Mini Cooper S to the Remus Racing Axle-Back exhaust but I had some questions.![Wink2](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
- Are all of the exhaust tips the same length or are some of them longer than others?
- Do the north american mini coopers require the connection tube for installation?
- How much should I expect to pay for installation if I take it to a shop? I asked one shop and they quoted me $500cad (~$370usd)
TacticalTortoise (07-23-2024)
pokochan (07-24-2024)
I purchased this: Catback Option for my Canadian 2018 Cooper S about a month and a half ago. If you have an exhaust hanger removal tool Its like a 20 minute job to swap the stock for this. andyes it will fit.
In fact it has also since been moved over to my 2024 JCW and fits without issue.
the "not for facelift" is a disclaimer required either because of emissions laws prevent them from marketing it that way, or less likely because they have not verified fit.
I can verify that it will fit for you! if you have any questions about it ask away.
And if you happen to be relatively local to me I might be able to help! send me a message!
The exhaust tips may vary in length, but the way you clamp them down you have some play in how far you might want them sticking out anyway
I'm not sure what connection tube your talking about. as my hands on experience is with the catback version.
cat back option all you need is some simple tools and a way to get the car off the ground enough to access the entire length of the exhaust.
As johnnys2quick mentioned above the axle back requires cutting and this is significantly more unnecessary work.(*unnecessary depending on your local Laws*)
And if you happen to be relatively local to me I might be able to help! send me a message!.
On the catback exhaust page that you linked, it says "The distance tube U7 (SKU: AD0181) for mounting the cat-back system on China/USA/Korea models must ordered serparately.", did you have to order that part? Or are Minis in the USA different from ones in Canada?
TacticalTortoise (07-24-2024)
Oh interesting.
Both of the facelift versions of remus exhausts offer a "connection tube" as a $200 option. It doesn't mention if it's required or something that would allow you to get away with not having to cut the stock exhaust. But hearing that the pre-facelift exhausts are compatible with facelift minis is a huge relief since it'll be substantially cheaper.
it lists the Kit contents as follows :
102mm Angled-Cut Carbon Exhaust Tips - Pair (or pick some more reasonable tips!)
Cat-back system consisting of:
70 mm stainless steel front silencer replacement tube,
1 stainless steel connection tube and
stainless steel sport exhaust (without tail pipes) with integrated valve
Sound Controller/Electronic Module/Electrical Actuators/Wiring
Remus Turbo Exhaust Adapter
The names of the different parts seem to get changed/lost in translation from place to place so its difficult to know for sure,
but this link from Way Motor Works shows clearly every item exactly how I had received them from ECS (aside from the tips being different).
The guys at Remus Canada were also supper helpful over the phone when trying to get some replacement parts.
If your planning on ordering from Remus Canada direct, I'd Suggest giving them a call or shoot an email with this information and confirm all the parts needed with them.
Also note that the sound control module is not mandatory but its nice to be able to close the valve when/if you feel like being less obnoxious. ( mines open 99% of the time anyway! lol)
I actually ordered from ECS here: ECS Option
They are definitely expensive.
I think the gloss black tips or even the angled chrome depending on your trim color would look fantastic as well.
Drivetrain Doug Thorley Cooper S Exhaust ???
tropicatango
06-04-2008 06:29 AM
