F55/F56 Project Thread: Celia (Midnight Black)
Old 01-10-2016, 09:29 AM
DustinFennell's Avatar
DustinFennell
DustinFennell is offline
The brushed titanium wrap looks awesome! I'm diggin' your black wheels better than the wheels on your mockup. I think it is just the black color. Do they make those Motegi's in black?
  #52
Old 01-10-2016, 10:13 AM
MidnightF56's Avatar
MidnightF56
MidnightF56 is offline
Yeah, they make the Motegis in a matte black that's kinda cheap looking to me, and all the black on my car is gloss so I wasn't quite convinced.
  #53
Old 01-12-2016, 08:51 AM
Escoozi's Avatar
Escoozi
Escoozi is offline
That color combo is sooo slick! Love it.
  #54
Old 01-15-2016, 04:23 PM
7rager's Avatar
7rager
7rager is offline
Originally Posted by MidnightF56
I have, rather unfortunately, encountered a loud clunk from the front suspension when under loads like braking, cornering and even sometimes accelerating. It seems to come primarily from the passenger side, but who knows how the acoustics are actually being transmitted. I can feel it through the footwell and transmission tunnel when it happens as well.
Still trying to diagnose it, but I'll keep this thread updated in case others encounter the same issue.
I get a clunk when going over speed bumps..
  #55
Old 01-21-2016, 07:09 PM
MidnightF56
It ended up being something with the control arm - and there's also something happening with ball joints that your dealer should be able to give you more info about.
  #56
Old 01-21-2016, 07:12 PM
MidnightF56
So I bit the bullet with the upgraded wheels and tires! Also sporting a new vanity plate
The wheels are the same size, but much lighter, and with a 45mm offset. I went wide with the tires, they're 225/45/17. The wheels weigh about 16lbs vs stock 21.5lbs for the stock Cosmos wheels, but my tires are slightly heavier than the Continental non-runflats I had before. All in all, I saved about 14lbs total in unsprung weight from the car.
They're definitely a step up in terms of both grip and ride comfort. I'm still exploring the setup a bit since it feels so different - I'm not sure if I feel some squirreliness in tight corners from the extra sidewall or not.
Before:
After:
  #57
Old 01-22-2016, 07:28 AM
ECSTuning is offline
Received 2,091 Likes on 1,865 Posts
looks good. Have not seen those on an F56 yet. Like the florida plates.
  #58
Old 01-22-2016, 02:34 PM
MidnightF56
I thought the colors on the plate went well with monochromatic scheme on the car, and it's of course a reference to John Cooper.
  #59
Old 01-22-2016, 02:48 PM
I like it. Have a great weekend,
  #60
Old 01-28-2016, 06:57 PM
gtmotor's Avatar
gtmotor
gtmotor is offline
Love the new look (wheels and tires)! I'm not a huge fan of black wheels so I think it looks a lot better.
What would really set it off is to make the wheels the same titanium color as the roof and mirrors in my opinion.
  #61
Old 01-28-2016, 08:25 PM
MidnightF56
I also think it'd look cool, but I've been cautioned against wrapping the wheels as it apparently doesn't last too long and is a PITA to do curved wheels.
I've been debating plastidipping them a color thats close to the titanium, but idk... the plastidipped wheels I've seen don't seem to wear well.
  #62
Old 01-28-2016, 08:33 PM
gtmotor's Avatar
gtmotor
gtmotor is offline
I've had good luck with plastidip on wheels. The trick is the surface prep and to make sure you get enough of the product on there.
https://www.dipyourcar.com/Kit-Wheels-cat/
I'll be using this on a set of aftermarket wheels (gloss white) as soon as I kill my stock tires.
  #63
Old 01-29-2016, 09:53 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is offline
Vendor
I really like them as is on your MINI. Really go well with your roof and mirrors.
888.280.7799 | 6am - 5pm PST
  #64
Old 01-30-2016, 05:06 AM
randomquickness's Avatar
randomquickness
randomquickness is offline
looking good, what's next?
  #65
Old 02-01-2016, 08:43 AM
+1 , excited to see whats next.
  #66
Old 02-05-2016, 10:18 AM
Blues Trucker's Avatar
Blues Trucker
Blues Trucker is offline
Those look real nice. Im just worried about quality of materials and workmanship considering country of manufacture.
  #67
Old 02-10-2016, 07:17 PM
MidnightF56
Of what? The wheels? Sure, they're made in China but almost every affordable wheel these days is. No problems thus far - they're round and they're light.
  #68
Old 02-11-2016, 06:17 AM
Whats the weight ?
  #69
Old 02-11-2016, 10:22 AM
MidnightF56
Whats the weight ?
~16lbs per wheel
  #70
Old 02-11-2016, 10:29 AM
Pretty light, like an OEM 15" wheel. Back in the day the Genuine MINI R71 Hollie 4x100 wheels were 12.0 lbs.
  #71
Old 03-15-2016, 06:22 PM
clevelandrum's Avatar
clevelandrum
clevelandrum is offline
Can you describe the procedure for installing the wheel spacers? Do you stick them to the wheel with grease, and then mount the assembly?
  #72
Old 03-15-2016, 07:36 PM
MidnightF56
No, no grease is necessary. You just mount them up on the hub, align the holes, and then mount the wheel. A bit like a sandwich, you just need to make sure the holes are properly aligned so you can tighten the lug bolts smoothly.
  #73
Old 03-16-2016, 05:09 AM
You can add some anti-sieze for people in salt prone areas, any metal likes to stick to the rusted rotor hat. That way if you ever take them off , they will come off easier.
Here is a DIY for measure and install.
F56 / F55+ wheel spacers here , full kits have the correct length new longer bolts.
https://www.ecstuning.com/News/Mini_F56_Cooper_ECS_Wheel_Spacers/
  #74
Old 03-16-2016, 07:30 AM
chiguy20002's Avatar
chiguy20002
chiguy20002 is offline
Looking great so far! I am not planning to very much extensively to my car, but I will start a thread for it also. Will be plenty of before and after. I wasn't sure about the silver wheels on your car because I like black wheels, but I think it looks really nice with the silver mirrors and roof. I will end up getting a set of black wheels for mine.
  #75
Old 03-16-2016, 07:37 PM
clevelandrum
thanks for the info!
hemisedan
08-09-2021 07:05 PM
07-16-2020 12:54 PM
NYXF56JCW
01-22-2016 05:32 AM
kyungmanpark
08-23-2015 07:26 PM
SDMini_me
08-07-2015 08:10 AM
Quick Reply: F55/F56 Project Thread: Celia (Midnight Black)
