Aftermarket wheels that fit R56 JCW brakes
#176
I'm getting some Traklite 1.0 wheels tomorrow from someone local that are a 17x7, so hopefully they will work out. if not, they will be up on the market place here.. hahaha
#178
#179
#180
Okay I've read through nearly this entire thread. It looks like if I buy a JCW Coupe in the next month that when prepping it for winter:
A.) I will not be able to fit a 16" wheel on it because the JCW brakes are too big.
B.) If I end up waiting for the GP, this problem will be even worse because its brakes are even bigger than the JCW.
Have I got that about right? I'll need to buy a 17" wheel/tire package for snow? I really wanted to go 16" for that.
#181
#182
Thats what I've done and granted, you have to run a slightly wider and slightly lower profile snow tire than would be preferred, it still works pretty well.
AND then you can buy a lighter summer wheel/tire package that is, IMO, more useful.
I found a nice set of Rays/Volks 17x7.5 et42 that work perfectly and are light!
Good Luck.
Rich
#183
That's the JCW Brembo front setup.
--Dan
Mach V
#185
Dan I was simply stating what the dealer told me.. If mine are just a red pair of brakes with a JCW logo on it, then so be it.. the dealer said they were JCW brakes and that is why i joined on to this thread.
There are in fact 2 sizes of brake kits you can get from JCW. if you dont believe me, look it up on the shipminiusa.com site. there is a 16" kit and a 17" kit.. the dealer said I had a 16" kit..
This thread is about the factory-issue Brembo front brakes that come with every 2008+ JCW car. None of the 2008 JCW models come with a smaller set of brakes, although there are some dealer accessory brake kits for non-JCW cars that are labeled as "JCW."
Although the brakes above are red and have JCW logos, they are standard-size R56 brakes.
--Dan
Mach V
--Dan
Mach V
#186
#187
#188
Rims or Wheels? What is The Correct Term?
Rim....The part of a car that the tires go on.
Wheels can be anything that rolls or a combination of a rim and a tire.
A wagon has wheels, a bike has rims or wheels both are correct.
The edge of the Grand Canyon is referred to as a Rim.
The term "Rim" has morphed to "wheel" ever since a certain segment of the population has adopted the term for things other than auto parts.
So you are correct and incorrect at the same time.
If you bent the rim on your 66 Road Runner you would have replaced the old "Rims" with Mag "Wheels".
In Short the term "Riming" once adopted by the afore eluded to segment of the "poopulation" has been replaced with "shopping for wheels" so as to more correctly describe the activity you are about to undertake
Perhaps now that you know the explanation and it won't bother you so much in the future
#189
RIM.......Rims.......*******.......Re-Rim......Rimmed
#190
I guess it bowls down to samantiks on the wheel thing, if your buying them the sales guy doesn't care what you call 'em as long as you have the requisite amount of cash to complete the sale.
#191
--Dan
Mach V
#192
Okay, but that's NOT WHAT THIS THREAD IS ABOUT. To avoid confusing the issue, please do not post pictures of R50/R53 brakes in this thread. The topic is wheels that fit over the R56 (Brembo) JCW brakes. Because the R56 JCW brakes are pretty big, many wheels will not fit over them. Hence the need for this thread.
--Dan
Mach V
--Dan
Mach V
You got a guy with an R56 with a set of brakes that he says came from the dealer that clearly say JCW on them and you wonder why he is confused and posted here? And he won't go away when you tell him to leave with no explanation and gentle "let's get back on topic"?
Sorry for trying to help
#193
Hmmmm...
--Dan
Mach V
#194
#196
--Dan
Mach V
#197
#199
Here's a car running an 18x8" wheel. I had this size on my own 2007 Cooper S.
...you also need a 42 offset to fit the JCW brakes.
225 40 18 will fix the speedo error and they fit nicely in the wells.
--Dan
Mach V
#200
