Power loss after reflash/reprogram?
#26
on
I'm been watching this thread, and is the problem only isolated to the Factory JCW, or the JCW Engine Kit as well?
Post 14 (https://www.northamericanmotoring.co...90-post14.html) indicates that he's having the problem with his Mini with the JCW Engine Kit, but I thought I'd check just to make sure.
#27
As i see it the issue is purely a fault in the current software update data. Any reflash to it is dropping the JCW settings within the car and setting the car back to standard MCS settings.
Hope this helps.
#28
same thing has happend to me..
after a software update
i basically hate my car..
it feels slow and boring and dead..
ive considered selling it many times since then
my dealer basically tells me tough ****.. sux to be u..
I wish i never went to them.. I would of rather voided my warranty..
*******s..
i'm seriously considering a after market ecu flash now.. or dumping the car..
*******s..
#29
Ottoman - mate i
[FONT=Times New Roman][SIZE=3]Get your frustration it sucks when you have to fight for them to respect what you are saying is truthful and stop treating you as an idiot. Luckily for me the service manager at the dealership I had the car serviced at when it all happened was a decent bloke and I think the evident from this site and the British one helped as well. [/SIZE][/FONT]
[SIZE=3][FONT=Times New Roman] [/FONT][/SIZE]
[FONT='Times New Roman']Here in Aust - Mini have a service contact number for owners do you have that in the US. Mini worldwide would know of this issue and it’s a warranty issue so dealer makes money anyway. [/FONT]
#30
#32
The software is not located at the dealer. It's installed from a network. It does take hours to flash since the BMW/MINI servers abroad are REALLY slow. It took me 3 1/2 hours the last time I coded mine for a retrofit.
#36
RA Instructions for removing and installing electronic control units.pdf
#37
on
Found update for FRM module. Programmed. CAS and Other Control Modules Updated. All Function. Are Good.
I'm going to give him a call tomorrow and ask him if he can confirm if the ECU was indeed programmed with the "S" code, and if I can bring it in with my CD and have them re-install the JCW ECU code.
#38
So I just did HelenBlitz with a crew of Minis. My tuner was there so I asked if he could see what he could do with my car's mapping.
As stated in this thread I lost boost and power after my '09 JCW was reprogrammed for window roll-down problems...
He was able to pull down my map but ironically it was the first time he had seen this series of map versioning in all many cars hed seen. Because of this he will be unable to make any mapping changes until he gets a keycode from some Italians. He will be able to compare the map with other JCW and Coop S maps he has on file before then however.
Being that the day was busy I'll know in several days what the results or should I say problems are, and by next weekend I might be able to get something more appropriate. I'll update when i know.
#39
#40
This is an update from the OP. (the thread seems to have melded w/ other models even though its in the "factory JCW (2009+) category)
I got a call from MINIUSA today. They said they were taking me off of the PUMA case. Their reason was because I measure my boost/performance with a scangauge. They said they would only take numbers from a MINI boost gauge. SO while the PUMA case is still open and there is no resolution yet, Im SOL. Three weeks ago my dealer asked me to come in so they could measure the performance of my car. They told me over the phone they would do this by plugging the car into their diagnostic machine because they measure boos in BAR not lbs. When I brought the car in a tech took it for a drive. Apparently testing it that way. BY redlining the car up and down a side street. The result of his expert "butt dynomometer" is that there was no loss of performance.
So my options are this. 1.) buy a mini boost gauge and have them install it just to show them that they messed up my car. Cost to me, approximately $500. 2.) Wait for a resolution of the PUMA case and a new program to come out. Go in and pay $100 +/- to have my car reprogrammed.
I told them this was absurd. I told them I was going to post this. I told them that up until this point I had been very impressed with their handling of the situation, but that the outcome has left me both frustrated and disgusted.
#41
THE PROOF IS IN THE PUDDING!!
Dyno results attached from pulls I just made yesterday.
Red lines: STOCK from 6 months back (Before mods or dealer reflash) SGII showed 20.5psi
Blue lines: MODIFIED (Forge FMIC, Craven filter, Turbo muffler charge pipe, Turbo noise maker delete, and finally a custom 2.5" Turbo back Catless exhaust pipe) - And oh yea... a shiesty DEALER REFLASH!! SGII showing 15.5 PSI on the Dyno
Just look at the numbers. Blue line still 10-25 HP below what it was when STOCK!!! With the supporting Mods I should be at least more than it was when stock.
I almost swear now that the dealer flashed my car with a Cooper S map. In a few days my tuner will be able to tell me more about that.
DO NOT GET YOUR CAR REFLASHED!!!! If you do you will be sorry!
#42
It can be a little difficult to compare before and after with 6 months time in between. Also SG II does not show you the max boost, only the boost at an instance in time. But it is not continuous reading but polled. Even with the fast polling rate, there is still a lag between readings.
#44
#45
What software version does this power loss occur on?
I pushed the buttons on the tach and mine says
IP Prod date: 11/06/2008
SW: 86.51.00
I have not gone to the dealer to fix my window because of this thread. I don't think there is any power loss in my car. I'm just curious as of which version it started happening.
SW: 86.51.00
#46
Then you should have 1.2 bar boost but you are getting 0.8 bar.
It can also be the stuff you have put on or some leak somewhere. Not all mods play well together or add HP as claimed.
Theres no excuse for the dealer's 'abuse' of their programming power.
I'll be back in just a few minutes with Tach / SW version.
#47
I just tried holding the Tach buttons and got something wierd/different than Stimpy but maybe I'm doing something wrong.
Key in, engine off. I press both tach buttons for ten seconds and I get
01.00
VIN: TF97xxx
-and no software version.
If I continue to hold both tach buttons the guages do an around the house display and then everything goes back to normal display.
Can anyone else in this thread confirm these results after dealer re-flash??
01.00
VIN: TF97xxx
