Power loss after reflash/reprogram?
#76
I know they reflashed mine too. Let me know if it gets fixed CinciJCW. I was going to bring it in, but didn't. I am so annoyed I started to look for tunes. I have to look which SW I have.
Has anyone had it fixed??? I imagine no one has, but there's got be something we can do. Mini just screwed us!!!!
#77
Update on changes since new Software Update
On sport setting the throttle mapping (not to be equated with a change in real engine power) has DEFINITELY changed with the new software. I find it less aggressive than before, a good thing IMO. Steering effort seems to be slightly increased but barely noticeable (assuming it's not just in my head).
With the sport setting off the throttle doesn't seem as 'lazy' as before. It is more sensitive to slight movements but still a bit laggy IMO. Steering effort seems the same.
All in all the pop and burble is down although I get hints of it when I'm in at least sport mode and rev it high.
As far as real power I'm not so sure. Peak power seems about the same but it appears that maybe I'm not getting max power at each point in the RPM band at wide open throttle. Without a dyno this is going to be impossible to prove (at least for me). Mini could (in theory) keep the peak HP/torque numbers the same but drop off the amount of time the car spends in overboost mode and not run afoul of the law as long as they key the 'peak' numbers the same (or better) than advertised.
BTW, it appears that the new software update is not just limited to us here in the US. If you do a Google search it appears that there are some Germany models that have the same software update (at least according to version numbers). It also appears that the same software version is used for S as well as JCW models.
#78
#79
My wife has an 09 JCW Convertible and I have a 10 JCW Clubbie. As soon as I drove the Clubbie, I noticed that it seems to have a less aggressive throttle response, the exhaust is less "raucous" (pops and burbles less), and seems to have less torque steer than the wife's car (all in "Sport" mode). Both cars have the 8C.50.00 SW version. I've only had the Clubbie for a week, so I'm withholding judgement....as I recall the 09 JCW didn't have as much exhaust "music" when new either. I think it's interesting that the SW versions are the same....I wonder if the New mapping (if indeed it affects the engine management) isn't reflected in the SW release number.
#80
#81
on
Has this been addressed by Mini, or has this just died becuase we have no re-course with Mini?
I even mentioned this on Mini's official facebook page hoping that a negative posting from a owner would get their attention, but so far nothing.
Guess it's not a problem they see, or they are chosing not to address the issue.
#82
I contacted MINIUSA about the topic and instead of responding they referred me to talk to a local dealer.
"Thanks for writing MINI regarding the software installed on your vehicle. Since your inquiry is regarding a technical issue, we suggest contacting your authorized MINI dealer. Your service team has the expertise to provide you with detailed technical support to fully address your inquiry…
LET'S MOTOR.
Ashley Paras MINI
Customer Relations and Services Representative"
LET'S MOTOR.
Ashley Paras MINI
#83
#84
#85
#88
update...
the rattle came back, so i took it back to the dealer. they reprogrammed (sw is now 8c.50.00, was 86.51.00) and replaced a bunch of parts (set of profile gasket, chan tensioners, sprocket, bearing bolt, guide rail, gasket ring, bearing bolt, timing chain, slide rail, torx bolts, hex bolt).
i let the car sit for 4 hours, started her up, and i still have the cold start rattle. the pop is gone, but somehow i can still hear a little burble...
#89
#90
i tried dropping my car off back to the dealer, but wasn't able to since they ran out of loaners. my sa seems to be very concerned that the noise isn't going away.
i decided to drive around and test some things out. all kinds of steering in sport/non sport feels the same. although the way the car acts to my throttle inputs is definitely different. it doesn't feel as quirky as before.
-in either sport/no sport mode: before the reflash, if you drove off and quickly came to a stop (from around 3k rpm or above, you clutch + put in neutral and brake right away), the rpms would drop quickly down to .75k rpm then go back up to around 1.5k and slowly back down. with the reflashed software, the rpms just drop at a slower rate than before without going up n down at the end.
driving as quickly as i could from a stop (without going over the speed limit, maybe ), i do not notice much difference.
when you are on gear and try to floor it, it has some lag before taking off. before reflash, there was very little lag if any.
-not in sport mode: when shifting between gears (at approx. 3k rpm), i'm feeling about 2 seconds of lag as compared to before when accelerating as soon as i get into gear. before the reflash, i would always have to worry about being gentle with the gas because the car always wants to "go-go-gooo".
-i can still make a pop in sport mode with when quickly accelerating and shifting at rpm around 3k (from 2nd to 3rd). it used to pop loudly in the 3.5-4k rpm range (on all gears).
#91
on
Yeah, I hope MINI gets this resolved as well. I'm starting to get paranoid about taking mine in for any servicing on the off-chance they might re-flash the software (mine's still the original 86.51.00)...
Based on what I've been able to discern from the opinions (mainly using "butt dynometers" and Mk I eardrums, so to speak) on these and related posts, there does appear to be a direct correlation between a JCW vehicle that's programmed with SW 8C.50.00 (as opposed to 86.51.00) and reported losses of power/exhaust burble... Is it really that difficult for MINI to connect the dots and figure this out...?
#93
dropped off my 09 jcw at the dealer today...and my sa said..."we'll see what we can do" (about the cold start rattle)
those words don't sound too encouraging...
i forgot to bring up the engine software, so i'll probably call tomorrow morning. i just have a bad feeling that they won't do anything about it.
#94
another update...sa said "the tapping noise that you are hearing on a cold start is normal"...uhhh...sssssuuuuurrrrreeeeee...if the tapping noise was normal for these cars, i would have heard it from the very first day of buying the car brand new.
oh yah, one more thing. when i mentioned that the software is now different from what it was originally, sa said "everything was updated on the reprogram"...
mini service is really grinding my gears lately...
i'm not praying that my car breaks down completely...but if that day ever comes, they will definitely hear from me.
#95
i have an 09 JCW, i see that this thread hasn't been updated in a year, well i took mine in for the 2nd time for an issue rough idle and engine dying (16,000 miles) and first it was "carbon build up" 3 days later cars a POS again, engine light, they now say "bad fuel pump" replaced that....no engine light BUT the car is a slow dead pig....from idle to 4k its down on power what feels like 20%, and literally at 4100rpm the car FALLS ON ITS FACE 4 grand to redline there is just nothing there, its slightly faster than just a mini and not even close to a MCS, the loaner they gave me a MCS automatic, would smoke this JCW, my 09 Xterra would smoke this JCW....I don't even want this POS any longer its ridiculous, i love that car, its been amazing to drive...and i haven't contacted them yet on this, but reading here its sounding grimm, but I'm pissed and needed to vent and see if anyone has had this resolved yet...Its insane to feel the power just completely fall off and have nothing from 4-6500, its now a Corolla and I'm not even joking....bland, quiet and boring....without going aftermarket which i will if i have to, has anyone got there bad ref lash fixed by Mini yet?
#96
Im a very sad girl today:( My precious 09 JCW has been literally rapped of her power and characteristic pops. Check engine light came on took it in to the mini service department, HP fuel pump was replaced and now my car runs like a damn cup cake! The dealer is acting like I'm crazy and have no idea what Im talking about because I'm a girl and lack a *****. Any advice?
#97
on
I suppose it's possible they re-programmed the car with the HPFP replacement, but in recalling this particular thread, I don't remember anyone complaining about such a severe power loss with reprogramming...? If they did reprogram the car, is it possible that they loaded an incorrect software load...? The service paperwork you should have received when you got the car back should detail whatever was done.
Soooo many ways to get myself into trouble there... Perhaps I'll just leave it to our respective imaginations...?
#99
mini claims that they definetly dont detune, since my last post i have been back AGAIN for yet another check engine light....so back to the dealer again, really nothing new to report, but i swear all of this started after the Carbon Clean job, so FYI, I asked the dealer, and if you get the Carbon buildup 4+ hour work done, the end of that is a reprogram....essentially your screwed if you do, screwed if you dont
#100
Wonder if their claims for 208 and 210lbs at overboost were a bit premature and now they realize it can cost them some issues with service/warranty, so they bypass it by tweeking the MAP. Of course, with only a few hundred JCW's a year, they aren't going to bother doing a whole lot for us either to correct the problem. I'll call my service guy today and mention the PUMA and see what he says.
