Took my 2009 JCW in for the recall & guess what?
on
My dealer not only done the rcall but checked my Timing chain and replaced all of the componants such as the tensioner,chain, rails,and everything else related.
They drained and replaced the brake fluid system, Replaced the cabin filter, and updated my computer to the latest program. They seemed to check every single part of my car.
*****And they did it all in one day so I just waited on it. I took the shuttle service over to the Mall and seen a couple of movies and ate while they worked on my car. When I got back to the dealer I test drove an "S" with the automatic transmission. Padel shifters are great. It was a nice enjoyable day in Orlando away from my house in Daytona. If I was home I never would go to the movies.
Orlando Mini has to be one of the best car dealers in the country just for the service and way they treat their customers and It is only A one hour drive from my house.
No, it is the little black part you see when you do an oil change, it is next to the oil filter housing. Remove the 10mm holding the coolant tank and push it out of the way and it is down there.
on
No I did not ask about the timing chain stuff
I did not ask because I did not even know I had a problem. The Guy that signed me in informed me that they received a bulletin about the tensioner and asked me if I wanted them to check to see if it needed replacing. It had to much slack in the chain so he asked me if I wanted it replaced. He said it would take most of the day. I told him I would wait for it to be done so I got the shuttle to take me to the Mall. I did ask them to check anything they could while I was there so they did and replaced the cabin filter, Drained and replaced the brake fluid and checked everything else. They replaced the original program on my computer to the very latest.
I really like this dealer (ORLANDO MINI) and wish all car dealers were this good to their customers. I had a Corvette before and I'm hoping I never ever see the inside of a Chevy dealer again in my lifetime.
I did get to drive a new "S" with the automatic transmission. I may eventually have to trade my JCW in for one due to my hip and leg getting A lot worse from long time ago injuries. It's really sad because I really love my 2009 factory JCW and it has been the most reliable trouble free car I have ever owned. It still thrills me to drive it until I get stuck in stop & go traffic. Then my hip and leg hurts so bad I can hardly stand it and have to stop and walk around.
I kind of liked the "S" and will probably put the JCW stage one engine kit on it as well as the extremely great sounding JCW exhaust.
Orlando Mini does sell OZ wheels now so I would have to go for a set of them installed.
I go back to the VA surgeon's in September and see if they can do anything for me this year. I see them every two years and so far no new treatments but this may be the year they found a new technique to help me.
Same here - if your car needs it - their system will pop up to do it. Just took the MINI in for the aux H20 pump recall a couple weeks ago. They also did the timing chain tensioner seal "service action" .
Very happy with NW MINI Tacoma service - they also did the 2 year service 900 miles ahead of time, brake fluid change, air filter, micro filter, oil change etc. Replaced a non op chrome boot latch even though it was added after purchase. Had a 2011 S loaner for the day to boot...... They couldn't wait to pull the car into service at 8:15 AM..... Service advisor had the paperwork in hand as we walked in the door to pick up at 5:00 PM.... Oh and sat in a sweet Roadster while I waited for our MINI to be pulled around.
Total cost. Zero dollars. *PRICELESS*.
Receipt reads:
PERFORM 11 02 12
CAMPAIGNS 50WP94M
1 11-31-4-609-483 CHAIN TENSIONER: 113050
13853 PERFORMED SERVCE ACTION. REPLACED TIMING CHAIN TENSIONER AND SEAL. (11 02 12)
(N/C)
Receipt reads:
PERFORM 11 02 12
CAMPAIGNS 50WP94M
(N/C)
If you need an automatic, the rumor is the revised JCW engine that will most likely go into production later this year will have an automatic option, at least on the Countryman. I am assuming if they offer that on the Countryman they would offer it on all JCWs.
Got the same treatment as well this past Monday...after my car threw the belt off the alternator pulley...for the third time at 17k miles.
In addition, I'm consistently getting over 40mpg (49.1, once) at freeway speeds.
Cheers...
on
Hi Herleman &&& mcmotorsports
You sure are right about Brian & Garrett at Orlando Mini.
I went in for the water pump recall and they not only did that but replaced my Tensioner componants and did all of the warranty work that needed doing. They even updated my computer programing to the latest program.
I don't think there is a better dealer anywhere then Orlando Mini.
mcmotorsports
There is no recall on the tensioner/ timing chain. The next time you go to your dealer just mention the service bulliten on that problem and let them check if your car needs the parts replaced.
mcmotorsports
Nope. No recall. It does appear that some dealers are checking cars for tensioner issues. If found, and under warranty, then they are making repairs.
There is a service bulletin for the chain tensioner and timing chain. If you think about it, it is a win-win for the dealer to look at this right?
1. They are being paid by MINI USA to make the turbo aux water pump fix.
2. If under warranty, they are also being paid by MINI USA for that repair.
3. If not under warranty, they will probably convince you to pay them for the repair before you trash your motor.
4. The additional work is probably less than book rate of the individual repairs if added up separately. (my guess. therefore making them more money)
The SA's computer told him our 2010 needed the timing chain tensioner & seal "service action". Before the car ever was in the service shop.
Receipt reads:
PERFORM 11 02 12
CAMPAIGNS 50WP94M
(N/C)
CAMPAIGNS 50WP94M
(N/C)
on
Receipt reads:
PERFORM 11 02 12
CAMPAIGNS 50WP94M
(N/C)
Receipt reads:
PERFORM 11 02 12
CAMPAIGNS 50WP94M
(N/C)
What I did lodge a complaint about, and receive warranty work for, was a periodically rattling cold start rattle. The tensioner was replaced without any hassles, but here's where my confusion is creeping in: you received a tensioner, P/N 11-31-4-609-483; mine apparently received a different tensioner, P/N 11-31-4-609-482. RealOEM shows the -483 part number on their exploded parts diagram pertaining to my vehicle, but ECS Tuning carries both parts (see previously-embedded links) -- which appear to be essentially the same...
So, what's the difference...? The '09 and '10 models have the same engine, so...?
I didn't double check the part numbers but one is about 5mm longer than the other. This is a band-aid type fix that doesn't cost MINI much to do and hopefully, for them, gets the customer out of the warranty period before the whole chain and all 3 guides need to be replaced. I highly recommend that if all they did is change the tensioner to a longer one that you complain that the car is acting the same way. Hopefully they will do the complete replacement. If not, you'll end up paying for it because it will eventually need it. I had my car in 7 (yes, SEVEN) times for this issue, MINI never did anything except replace the shorter tensioner with another short tensioner. Three different dealerships and even calling MINI USA and nothing. I even changed to the longer tensioner MYSELF, since they wouldn't even do that. That worked for a few weeks and now I will be changing my timing chain, also myself.
on
I verbally asked the SA about the chain and guides, and he said all were inspected and were fine. I'm pretty sure they put the chain length measurement on my paperwork, but I don't have that handy at the moment to state what the measurement was...
I've heard some people state that unless the chain is replaced with the tensioner, it's only a 'half-fix.' With a given (longer-length) tensioner, how does a newer chain improve the situation if the older chain was unstretched?
