FJCW backfiring
Hello
I don't have an answer for you, but I too have a gergle/popin question.
Mine is a '14 R55 auto
I had the gergle n popin at first but then lost it right after I took it in for a oil change @ 3000 miles.
Not I only have a low drone
It gets louder but it doesn't do anything when letting off in the corners and shifting through the straights
Like you, I too would like to know from others what might need to be done or looked at
It's somewhat dependent on how hot the exhaust system is. So if you've just started the car or have been cruising on the highway for a while it'll happen less. If you've been driving hard it should happen more. The hot exhaust ignites the unburned fuel leaving the motor causing the "pops".
Navigation & Audio MidnightBlackCooperS audio build
F55MidnightBlackCooperS
Navigation and Audio
37
04-14-2016 12:55 PM
Marktheman
08-23-2015 11:45 AM
