F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Clear oily substance leaking from rear view mirror
Old 11-19-2014 | 11:26 PM
ColoradoF56's Avatar
ColoradoF56
Today I noticed a clear oily substance leaking from my rear view mirror. The substance is leaking down the windshield on the inside of the cabin. The rear view mirror is the one with the rain sensor. Has anybody else experienced this?
Old 11-20-2014 | 02:32 AM
F56_LA's Avatar
F56_LA
Sounds like it could be a small leak in the window sealer. I would definitely take it to the dealer and see what is up. That is not normal.
Old 11-20-2014 | 01:58 PM
ColoradoF56
The oily substance seems like it's coming from the rear view mirror and not where the windshield meets the top rubber gasket. And one other thing, there was no rain or snow so this is not a water leak. Is there some kind of auto dimming oil inside the mirror?
Old 11-20-2014 | 03:48 PM
sal1k's Avatar
sal1k
Sounds like some of the chemicals in auto-dimming mirrors. BMW has had leaky auto-dimming mirrors in the past. Just do a Google search for it. Definitely bring it into your dealer... no doubt it should be covered under warranty.
Old 11-26-2014 | 11:18 PM
ColoradoF56
Turns out it was the rain sensor gel pack that melted. The dealer has ordered a replacement and will install it once it arrives.
Old 11-29-2014 | 09:05 AM
DarkBlue15MCS's Avatar
DarkBlue15MCS
I just cleaned this off my glass as well. I will keep an eye on it to see if more leaks out or if the wipers start acting funny.
Old 02-22-2015 | 09:20 PM
fatherfork's Avatar
fatherfork
Mine is doing this now too. Did the replacement fix the problem?
Old 02-22-2015 | 09:36 PM
ColoradoF56
Fixed
The dealer installed a new rain sensor and gel pack. It completely fixed the problem. They had to order the replacement parts from Germany so it took a while to get to Colorado.
Old 04-16-2015 | 09:18 AM
hp79's Avatar
hp79
I have the same stupid problem on my 2015 F56 with build date Sept. 2014.
They need to get a grip on fixing these things before these cars are sold. I mostly like the drive experience, except the small annoyances are piling up for the next visit. Green mode miles most times don't accumulate on the gauge (stuck at same number even though I'm coasting at least a mile), more rattles on the door panels and the front dash somewhere. I still don't like how the automatic gear behaves in stop and go traffic when releasing the brake from a complete stop. It's not a smooth start. Idle start stop is pretty harsh too so I keep it off most times.
Old 04-16-2015 | 01:31 PM
Looks like it was the gel pack for the sensor and not the auto dimming glass fluid like on older 7 ser BMW' s.
http://www.realoem.com/bmw/enUS/show...diagId=61_3297
What was the part number for the gel pack ?
Old 04-16-2015 | 01:48 PM
hp79's Avatar
hp79
Thanks for the pic.
If this is bad by design, it's going to happen again in the future. I can clearly see air bubbles in that sensor spot now that few drips of the gel has leaked out.
I'll have to book a trip to the dealer.
Old 04-16-2015 | 10:32 PM
MasterYoda's Avatar
MasterYoda
I have the same issue. I was going to ask about it next time I take it in for service.
Old 04-15-2016 | 01:11 PM
hp79's Avatar
hp79
Does anyone has any update on this?
I replaced my rain sensor on my 2015 F56 for the fourth time now and I'm not even surprised that it's doing the same thing again. I drove maybe 100 miles since last replacement, and was parked in my garage that's around 20C all the time. It's the base mirror, not the automatic dimming mirror.
I even see that there's air inside the sensor gel pack area, where I think it should be completely filled with the gel and with no air.
Can anyone check if theirs is completely filled, packed with gel?
Attachments - Photo of the air pockets on the MINI, and a second photo of my 2014 Mazda CX-5 rain sensor with no problems.
Attached Thumbnails Clear oily substance leaking from rear view mirror-mini_f56_2015.jpg   Clear oily substance leaking from rear view mirror-mazda_cx5.jpg
Old 04-21-2016 | 07:11 PM
Camyman's Avatar
Camyman
I will check for any bulletins about this and ask around at work to see if I can't scrounge up any information on this one. Are the auto wipers working normally? How about the automatic headlights? We had this on a loaner hardtop and we ended up replacing the whole mirror assembly because the auto lights/wipers weren't working.
Old 04-21-2016 | 08:56 PM
hp79's Avatar
hp79
Auto wipers seems to work normally, but it's hard to tell if it's really normal or not. Headlights works fine.
Old 04-21-2016 | 09:40 PM
Camyman's Avatar
Camyman
If you hit the auto button and you get the first wipe they should be working. The issue with this car is that nothing would happen in auto for either thing. I will dig into it and talk with a tech when I get in tomorrow and see if they don't know of anything.
Old 06-15-2016 | 11:46 PM
hp79's Avatar
hp79
I got mine replaced again with the same part number. They said there's no revised part for this. Perhaps MINI thinks it's cheaper to replace the parts with the same defective ones over and over again. The brand new loaner F55 that I had (less than 1k miles) also has some air bubbles so maybe the air gap is normal. Previously I did experience the wiper sometimes working erratically even in constant rain (such as wiping three times continuously and then going back to it's normal 3 second interval rhythm).
Old 07-18-2016 | 06:40 PM
hp79's Avatar
hp79
Another leak only after couple weeks or so. Didn't drive much, mostly parked in the garage. Scheduled another appointment. Thank god they have loaner cars.
I hope they find a solution, otherwise I'm going to keep sending them in for replacement.
Attached Thumbnails Clear oily substance leaking from rear view mirror-20160714_201442.jpg
Old 07-21-2016 | 05:01 PM
Camyman's Avatar
Camyman
That is really interesting... I haven't found anything out about this. I am now in a different department but my Service guys still keep me in the loop. Let us know if this keeps being a problem.
Old 08-26-2016 | 08:21 PM
rmcintos's Avatar
rmcintos
Took a look at my 2015 F56 and sure enough it's leaking too. Will take it into be replaced by MINI soon, but posting here just to confirm another documented case.
Hopefully they recall this item and make a quality replacement.
Old 05-10-2019 | 12:23 PM
Imperial's Avatar
Imperial
Hi guys! I started seeing this recently on my 2016 Cooper S model. Just wanted to find out if MINI came out with an update or a fix before I go to the dealer?
Old 05-10-2019 | 01:22 PM
hp79's Avatar
hp79
There’s no fix. Official answer was that this gel is only needed for avoiding damage to the sensor during installation. Whether you believe them or not is up to you.
After three years of wiping off the leak, it stopped leaking. Maybe it drained enough that it no longer comes out. Rain sensor seem to be working fine.
Imperial (05-10-2019)
Old 05-10-2019 | 01:43 PM
Imperial's Avatar
Imperial
I will contact the dealership to see what they say, as the car is still under warranty in case it come in handy.
I started noticing this a week ago when we started to have a warmer weather after the winter. It isn't leaking too much, but I can see some of the gel. One of these warmer days, I adjusted position of my seat and need to re-adjust the rear view mirror as well. By doing this, I felt that mirror's movement is very fluid(had no friction) as if some type of lubricant was applied into the mirror's movement mechanism. I am thinking this could of caused some movement of the sensor's gel and it started leaking. Otherwise I don't remember seeing this gel before.
Old 05-10-2019 | 02:49 PM
hp79's Avatar
hp79
I probably had them replace the rain sensor gel pack replaced more than 5 times. They also swapped windshield. Eventually gave up. It leaks even if you park your car in a garage and not use it. Right before my warranty was up I checked one last time, they had a service bulletin saying gel leak is normal.
My mirror was also loose so they swapped out that. There’s lot of things that needs taken care of before the warranty runs out. I even feel sorry for those who don’t know of all these problems.
Old 05-10-2019 | 05:55 PM
Imperial's Avatar
Imperial
The mirror in my car feels loose only when I am trying to adjust it when it is warm/hot outside. If outside temp is not high, then it feels stiff when trying to adjust it. So the heat make the mirror ball joint seem fluid . I checked the rain sensor area from outside and that circle seems to be properly filled with gel. I hope that it is the excess gel is coming out and will stop. I started reading 3 or 4 year old threads where people were having this gel issue with hopes that MINI is working on a fix, but to this day, there seem to be no fix for it or as some point out "gel leaking is normal or gel isn't required".
If my mirror needs replacing, I will of course ask the dealer to do it, but if gel issue won't anyway get fixed, then "live with it" ?! :(
