General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
How about sharing your autocross secrets?
Old 09-27-2004 | 05:56 AM
BGarfield's Avatar
BGarfield
Hey Folks, although my finish this year can't back up my driving, my co-driver, Ian Baker, finished second at Nationals in the car in G Stock, so obviously the car was working fine...
What Keith said about Karter Bollman was correct and echoes what I've been saying for awhile: Improvements in the MINI are much less effective over how the stock suspension comes.
Although my car has Koni Single Adjustables ("off the shelf"), I don't believe they gain you any time at all. What they do gain you is adjustability, although the rear is not very friendly, especially when it's raining and then drying, since you have to drop the shock out.
What Keith has(had?) is the easiest because they can be adjusted without removing the rear shock. They cost a pretty penny over the Konis, but have more adjustability and are much easier, they even "click" for each adjustment.
All that said, my front has about 1/8" toe-out, the rear has about 3/4" toe-in. The rear toe-in is unusually high, but that allows me to throw the car with very good pradictibility. In the wet, you don't ever have to worry about "snap" oversteer.
Even the best drivers will drive differently and have different setups for their "style", so you can't always setup your car exactly the way another has and enjoy driving it. It would probably be best to do something generally in the same area as what you read hear and then adjust as you get faster to what you feel you need.
And finally, the obvious as suggested many times before, do some schools. For those of you in the Mid-Atlantic area, check out the Washington D.C. Region SCCA Schools http://solo.wdcr-scca.org/noviceSchool.php
They become popular enough to draw people from 6-7 hours aways.
Good Luck!!
Brian Garfield
  #27
Old 09-27-2004 | 06:20 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
Originally Posted by JiminVirginia
Also, don't you have to use a stock air box and filter?
In G Stock you can use any drop in filter you wish or run with no filter at all (the box must still be there), but no CAI.
  #28
Old 10-12-2004 | 03:45 PM
BlueMCS's Avatar
BlueMCS
So you get it to rotate by trailbraking? You must have small feet. :smile:
I'm running 1/8" front, 3/8" rear. Works fine but have to be gas on in the slaloms.
  #29
Old 10-12-2004 | 07:02 PM
scobib's Avatar
scobib
I've seen most of the really fast stock guys left foot braking to get their FWD cars to rotate in the corners... I'm still not sure how they do it because I'm too busy doing all kinds of other things, I guess...
Doc Pain
03-10-2021 04:50 AM
MrBlah
SCCA Solo and ProSolo
02-01-2020 07:43 PM
flpat73
11-02-2015 06:38 PM
AoxoMoxoA
Tires, Wheels, & Brakes
09-30-2015 06:00 AM
keen
GP Talk
09-16-2015 05:00 PM
Quick Reply: How about sharing your autocross secrets?
