Sunroof panels vs Solid Roof
My 04 has a sunroof. My 06 won't. Beside the obvious weight penalty (up high), you loose about an 1" to 1.5" in headroom. Wearing a helmet I've had to recline the seat back a bit in order to keep from hitting my head on the sunroof opening. It is nice when cruising on a hot summer night, but a bit noisey on the freeway. If you are concerned about weight, skip it and save yourself $800.
Someone put two identically speced cars on the scale, one with sunroof one without. The difference was 63 pounds. All in the worst place possible, way up high. But if you just have to have the sunroof the weight difference isn't enough to make the car uncompetitive, but it won't help you any.
I don't have the sunroof...
Never liked em, but I have to say the headroomm is AMAZING with the seat jacked down! I have tracked my car a few times and never even hit with the helmet.
My wife's honda Civic SI has NO headroom..... But that's off topic.
Save the money, save the weight.... If you really, really want light and air, go cabrio!
Matt
Matt
To back up Motoring's statement, SCC had a MCS project car (for one article) where they took out the sunroof and put in a carbon fiber panel. You can read the article but they weighed the roof itself to be 53lbs.
To tell you how bad the high weight is, Mitsu replaced the steel roof of the Evo VIII with aluminium for the Evo VIII MR. The difference was something like 25lbs but it effectively lowered the center of gravity two inches. Try that with just the suspension and you'll be ridin' on the bumpstops.
I have an 03 MCS with Sunroof and I have an 05 MCS without Sunroof on order. I would probably have deleted some other options after having read some great dialogs in this forum to save further weight. However, I struggled to take out "looks" options in favor of less weight.
I have been doing some autocrossing and while I feel the Mini is extremely steady and blast to drive in Auto-X I feel the Mini is a little top heavy with those glass panels in some corners want to lean over a little too much...
Per Olof Huntersville, NC
2003 MCS Chili Red with white Bonnet stripes and Sunroof
2005 MCS Chili Red with LSD, white Bonnet stripes, checkered roof & mirrors, Aero kit and driving lamps on order.
Did you get it yet?
And, is it everything you hoped for? I seriously considered skipping the sunroof. I got it and I like it a lot. It's a bit loud over 60 mph, but it's great for driving at lower speeds.
Anyway, I have a friend who needs to see a non-sunroof car to be convinced he needs a MINI. He works near where you live.
PM me if it sounds OK.
M7Speed
09-04-2015 10:47 AM
