General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Bad Rota Slipstreams ??
Old 02-18-2006 | 12:21 PM
JustGo4It_'s Avatar
JustGo4It_
Has anybody run into a problem with the 16x6.5 Slipstreams not fitting onto their hubs? I got a set of 4, two fit and two don't. A bad run perhaps?
Old 02-19-2006 | 09:22 PM
Thameth's Avatar
Thameth
So you got hub centric wheels and they don't fit on the hub center?
Old 02-20-2006 | 10:27 AM
JustGo4It_'s Avatar
JustGo4It_
Yes too small. .003-.005 by my best estimate. The wheel sits away about 1/4"
Old 02-20-2006 | 10:48 AM
Thameth's Avatar
Thameth
Dremel??
Old 02-20-2006 | 10:57 AM
JustGo4It_'s Avatar
JustGo4It_
Was thinking more like a cylinder hone.
Old 02-20-2006 | 11:36 AM
Thameth's Avatar
Thameth
True, hopefully the Rota distributor will work with on you paying for the needed modifications or send you new wheels. Were they custom ordered or pulled from availible stock?
Old 02-20-2006 | 10:45 PM
OasisT's Avatar
OasisT
I see that Rota lists them as being 56.1mm. Our hub is technically 56.15mm I think isn't it? I think this might be where the issue might be since they may have been mis-informed. I just emailed them on my 15x7.5 special order group buy to let them know about this issue.
Craig
Old 02-21-2006 | 06:48 AM
GRMPer's Avatar
GRMPer
I posted this over on Sccaforums, but I'll repost here.
I've got 8, four white that are fine, 2 gun/royals that are fine, 2 gun/royals that are tight..but maybe that's actually 4 guns/royals that are just tight on the rear hub...slip on fine on the front. I never checked the two "good" gun/royals on the rear.
anyway, a few zips on and off w/ the impact and they're fine. Maybe powdercoating on the inside?
Per
Old 02-21-2006 | 04:24 PM
JustGo4It_'s Avatar
JustGo4It_
They are more than just a bit tight, I've seen a few of those, these are to the point that I wouldn't want to use the lugs to put (pull) them on.
Old 02-22-2006 | 05:25 PM
JustGo4It_'s Avatar
JustGo4It_
A letter to 18racing:
Jessica,
I was able to resolve the problem. I used some 120 grit sandpaper and removed the paint from inside the hub. With the paint removed the rims slipped on perfectly. There must have been extra paint material on the two rims. I would not increase the hub size dimensions that you are currently using for production. My rear hub size measured 2.208 inches.
Thanks for your help,
James
navybsn
10-05-2018 04:42 PM
Fordgt4
10-10-2015 10:42 AM
schr5530
10-01-2015 05:11 PM
M7Speed
10-01-2015 07:05 AM
pkillur
Tires, Wheels, & Brakes
10-01-2015 03:59 AM
Quick Reply: Bad Rota Slipstreams ??
