Sticker Dilemma.
Sticker Dilemma.
The Stiker I'm talking about is the one warning you not to use elecronic devices and not to lock the car with the fob from the inside, its in the upper left hand section of the windscreen.
My 02 had it and I just left it there, but in my 07 it's badly placed; it has a little air bump and the two sides are peeling.
Should I just peel it off? Did you all peel yours off?
Im conflicted. Half wants to peel it off and half wants to keep it on.
must... kill... the... bubble...
can't leave those peeling ends on there. they are screaming to be tugged.
you can't resist.
it will drive you crazy.
it will wake you up at night.
one day you will lift the toilet lid, and the sticker will be floating around, corners peeled up and a big smiley bubble in the middle.
mmmmm.... OCD. embrace it
you can't resist.
you can't resist.
you can't resist.
Be sure to disconnect the negative (-) terminal on the battery before removing that sticker - you do realize that if you peel that sticker off you need to reprogram the keyfob, right? Certain functions of the keyfob cease to be available unless you reprogram the fob and the body function computer located beneath the passenger seat...
(and when your butt is in the air while your head's under the seat... WHACK!)
RobbyD
01-29-2019 01:22 PM
