My MINI Cooper 2-page spread magazine advertisement
Old 04-06-2009 | 07:58 PM
MrCooperS's Avatar
MrCooperS
Moderator
Originally Posted by artmem
Just saw the chick magnets ad. I like it better than the Suzuki concept.
I'd make the magnet the main image, rotate it a little and then flip the chick upside down and attach it to one end of the magnet. Make that fill the majority of the ad, and run "CHICK MAGNET" in all caps below with a tiny mini as punctuation, the same size as the text.
I'm not sure what you mean here by using a tiny MINI as punctuation? Rotate the magnet so it's pointing down? Corner? Hmm?
The problem is, designing the two page ad, I have to keep in mind of the "gutter" the crease in the middle of the magazine page. I wouldn't know how to photoshop around that.
Your input is amazing though and def. helpful. I wish I had the talent to be able to pull off everything you mentioned, but I've taken no graphic design courses, and learned Photoshop by myself a couple semesters back. After my class hammering tomorrow, I'll def. go over it again with your comments in consideration.
I think I'm def. going to ditch the second ad and maybe tweak my version 2 ad with the "Chick Magnet." If I do, I'll def. increase the gutter.
Maybe I'll ditch the whole idea all together and do a full page ad with the "Relax, it's just snow" idea, but I need to find a large and good quality pic of a 09 MINI Cabrio in a black background to crop it out and use...
But thanks for the input though. Your input is greatly appreciated especially from a experienced pro like you...stopping by Boston anytime soon? I'll buy you coffee.
  #52
Old 04-06-2009 | 08:17 PM
artmem's Avatar
artmem
No problem. I think your photoshop work looks fine here, at least at the size you've posted. And the typography is nice too (though for a typography final, I guess it should be ).
As far as the gutter goes, if you find a big image, you could stretch the car across the whole spread and not worry too much about it. just make sure that you don't run any words across the center. If you arrange the type so that the center falls on a space, you can just make that space bigger (around a half-inch or so) than the others and you should be fine.
Also, they're not on black, but here are some big cabrio images that would be pretty simple to knock out if you're comfortable with the pen tool:
one
two
  #53
Old 04-06-2009 | 08:22 PM
artmem's Avatar
artmem
I just mean make it tiny and run it inline with the text.
As far as the magnet, I don't know. I wouldn't point it up or down. I'd just stick the chick on the end and then scale/rotate it until it looks nice and fills most of the space. Maybe crop the butt off? Just something to make it a little more dynamic than just the straight horizontal alignment.
  #54
Old 04-06-2009 | 08:40 PM
MrCooperS's Avatar
MrCooperS
Moderator
The links you posted doesn't work.
I've played with the pen tool a bit. I use it to make curves and such, but I don't know how to crop with it.
  #55
Old 04-06-2009 | 08:52 PM
artmem's Avatar
artmem
Sorry. They worked for me. If you go to http://www.leftlanenews.com/ and search for mini convertible, there will be a bunch of articles listed. Most of them have photo galleries at the bottom, and you can blow up the photos to 2400px.
To cut out images, you basically use the pen tool to trace a line around the image. Then when your path is complete, there is an icon at the bottom of the path palette that looks like a dotted circle - the tool tip says something like "load selection from path" Just select your path and then click that button, and it should turn it into a selection. You can then copy and paste the car onto a new layer (you may have to select inverse first depending on your settings). Or, for a little more control, don't copy and paste. Instead, switch to the layers palette, select your photo layer (make sure it isn't the background), and click the "make layer mask" icon (the white square with a circle in it. This will make a mask that you can edit with the paint brush.
You can read about layer masks here: http://creativecurio.com/2008/04/mas...s-layer-masks/
Here is a good overview of the whole pen tool/clipping mask process: http://www.graphic-design-employment...ing-paths.html
  #56
Old 04-06-2009 | 08:58 PM
Sin MINI's Avatar
Sin MINI
Very late to the game, but I have an idea about the "third best performance car" line if you ever decide to use it.
Change it to read "Top performance car under $XX,XXX" (where XX,XXX is lower price of the two that finished ahead of it).
  #57
Old 04-06-2009 | 09:11 PM
MrCooperS's Avatar
MrCooperS
Moderator
:: Playing with pen tool now::
  #58
Old 04-06-2009 | 09:19 PM
artmem's Avatar
artmem
Good luck!
  #59
Old 04-06-2009 | 09:29 PM
MrCooperS's Avatar
MrCooperS
Moderator
My First Perfect Crop
oh man, artmem, you added a powerful tool in my tool belt. with this new skill, my next projects are going to be dangerous! instead of settling for the "ok" image with a black background, I can find the perfect image and crop it out with confidence. Amazing. Thanks a lot artmem.
  #60
Old 04-06-2009 | 09:33 PM
artmem's Avatar
artmem
Nice job. Glad it worked out for you!
  #61
Old 04-06-2009 | 09:34 PM
MrCooperS's Avatar
MrCooperS
Moderator
lol thanks. let me know when your ever in Boston. I gotta buy you coffee or dinner or something.
  #62
Old 04-06-2009 | 09:38 PM
AggieMini11's Avatar
AggieMini11
That looks good except the background is still showing through the windsheild. And that is hard ot get off. You need to google search how to get that off. Personally, I like the two page spread idea. You can do so much more and it is much more powerful
  #63
Old 04-06-2009 | 10:32 PM
artmem's Avatar
artmem
If you need to blend the windshield, you can knock out just the transparent part (don't include the rearview mirror and sun visors that you can see through the glass) and put it on its own layer. Then adjust the opacity and blend mode (the dropdown menu at the top of the layers palette) to make it look more realistic. What blend mode option works best will depend on the background and what is on the windshield, so experiment with different options and opacities.
  #64
Old 04-07-2009 | 10:29 AM
Rixter's Avatar
Rixter
Originally Posted by Btwyx
You don't need to enter that debate, but it does disprove your point about MS.
It was a generalization. Here above the 49th, I haven't even seen the MS ad that was being referenced. There are other examples though.
It seems to me that buying a car and a Mini in particular, is not merely buying yet another commodity item. The Suzuki ads try to make the argument that a car is a car is a car, therefore might as well buy the one that pound-for-pound is the cheapest. Please don't get me wrong, I'm not knocking the Suzuki product(s), however successful manufacturers like Mini, don't typically get into a feature set comparison. Rather they focus their marketing dollars on creating an image and evoking a feeling about buying/owning their vehicle. As my kids say you can't put a price on cool.
When you start to mention the competition in your ads, you start to delve into the area of feature comparison, which I doubt Mini would ever win. It doesn't have the most trunk space, horse power, most cup holders or lowest price of any other car in its market segment. It doesn't have to; it's a Mini, that's all that needs to be said.
  #65
Old 04-07-2009 | 10:45 AM
MrCooperS's Avatar
MrCooperS
Moderator
Doesn't matter...I scrapped the suzuki ad idea. Working on something el magnifique at the moment.
  #66
Old 04-07-2009 | 11:04 AM
Rixter's Avatar
Rixter
Looking forward to seeing it
  #67
Old 04-07-2009 | 11:06 AM
MrCooperS's Avatar
MrCooperS
Moderator
Alright. Here's the starting of what I'm doing. I have to go to work...will be working on it when I get back tonight. Let me know what you guys think so far.
  #68
Old 04-07-2009 | 12:23 PM
AggieMini11
Its beautiful. If you are going to actually put it in a magazine. You need to be aware of where the fold is going to be. I love the simplicity and color. Maybe cause I am wearing yellow and black today. (hmmm). Anyway, you may want to put "Mini Cooper '09 Convertible" or something just to name it.
Do a BRG ad next!
  #69
Old 04-07-2009 | 12:36 PM
Rixter's Avatar
Rixter
That looks great!!!
I'd suggest getting rid of some of the punctuation marks such as the period after "RELAX", or if you want to keep the punctuation make it a comma. Also perhaps make all the words lower case, more calming.
Looking fwd to the rest of the ad
  #70
Old 04-07-2009 | 01:01 PM
Gromit801's Avatar
Gromit801
Nice. Being an old fart, it reminds me of another "congratulations" ad from the late 70's:
  #71
Old 04-07-2009 | 01:15 PM
Rixter's Avatar
Rixter
Cracking toast, Gromit!
  #72
Old 04-07-2009 | 01:28 PM
Browser_23's Avatar
Browser_23
Sorry to nitpick but all the white (reflected light) really detracts from the car. Way too much of it.
  #73
Old 04-07-2009 | 02:14 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I just came up with a good idea for the 2 page same-theme ad that builds on your idea:
or something to that effect.
  #74
Old 04-07-2009 | 02:43 PM
ScottRiqui's Avatar
ScottRiqui
nabeshin,
Have I ever told you that I love your "Microsoft Paint" pictures?
  #75
Old 04-07-2009 | 03:00 PM
miniola's Avatar
miniola
WOW! You've really put yourself out there for criticism! Good for you.
I'm glad that you got rid of the Suzuki thing because when I first read it, I felt like that was the car a person SHOULD buy... thankfully, I know better!
When I see this snow ad, I think...
CHILL...
Bring on the SNOW!
(or something like that)
Perhaps I am a bit more confrontational with snow! Or maybe it has something to do with being a big dog in a little dog body?
Good luck on your project!
Nabeshin- that IS a nice paint pic of the car that you did.
