OctaneGuy's 2010 Clubman S
#26
#28
I'm not lowered yet..but I got H&R Street Performance coilovers in transit..UPS says they will arrive tomorrow. I think the angle you take the photos affect
The wheels are discontinued EdgeRacing.com Flik Bullets. The tires are Nitto Invos in 225/45 R17.
You can see how I modded these wheels here on Flickr
http://www.flickr.com/photos/octaneg...7604116553049/
I had to drill them out from 12mm to 14mm because of lug bolt sizing changes from the R53 to the R55. Also had to add the factory TPMS sensors.
I would think those WC50 lights would be pretty hard to come by..probably much like the GP where you need a VIN to order parts? I dunno...but thanks!
#30
#31
re: tach ring
yeah I got lazy, lol. I'm looking more for accents. Don't want to over power the interior. Here's what my R53 interior looked like for those that don't remember. I'm thinking the MFSW buttons might be interchangeable. I have a broken set that I'll test out and see if they fit or not.
Here's what my R53 looked like and where I'm headed with the R55 thought maybe not as far, lol.
#32
#34
Duplicolor Ceramic High Temp Caliper Paint. I left everything in place and masked it off with tape and a plastic trash bag.
I put 5 coats of paint on the calipers and 2 coats on the rotor hats.
I used Brake Cleaner to clean off the parts to be painted. Used a wire brush to help. After repeating this several times, I sanded the parts with 320 wet/dry paper and once again rinsed everything off with Brake Cleaner. Then I masked off the parts I didn't want painted. I painted the rotor hats first with 2 coats of black..always use thin coats. Then I covered the rotor with a plastic bag, and painted the calipers. I did tape off all the rubber seals, pads, anything I didn't want to get paint on.
The red paint I used
The black paint
The Cleaner
With the tape removed off the hub
Because I only had one jack, I did one wheel at a time. I started at about 12:30noon and finished by 7pm.
iPhone pix
iPhone pix
I sprayed directly from the can. I also touched up using a brush and a plastic cup that I sprayed the paint into.
Hope that helps!
The black paint
The Cleaner
iPhone pix
iPhone pix
Hope that helps!
#36
You're welcome. Remember you can spray a new coat within 10 minutes. You have to finish layering within 1 hour. Because of the heat, and I put a fan to help dry it, I was layering every 5 to 10 minutes and have no runs or drips in the paint. Make sure to clear the nozzle after every use. This stuff dries quick and hard.
#37
Today Windigo Independent BMW and MINI here in Anaheim Hills did the work to install my H&R Street performance coilovers, Ireland Engineering fixed camber plates, IE adjustable sway bar, IE lower control arms. The ride is great so far! Very compliant yet stable and sure. Will be putting on a couple hundred miles tomorrow, but so far, it's feeling great.
#39
#42
#45
#47
