Hypermiling on Steroids!
Hey Everyone.
Over the past week I've been pushing my MINI to get the absolute best mileage I possibly could.
The good news: I reached a whole new mileage high out of one tank of gas!
The bad news: It wasn't easy and I almost gave up a few times.
Check out my story on my blog: http://goo.gl/WbXSD
Thanks Everyone! Please post comments and feedback.
John Lindauer
DrivingMyMINI
www.drivingmymini.blogspot.com
John Lindauer
DrivingMyMINI
Since you reference your shift point, I assume you have a manual? If so, not using the Sport button didn't do anything for your mpgs.
2,000 rpm shift point seems a little low - may have lost some efficiency due to the engine lugging a tiny bit when you hit the next higher gear. Sweet spot seems to be in the 2,600 range give or take.
If you were really committed though, you would have gone and got some skinny LRR tires before starting your experiment. :-D
hypermilers are a pain in the a$$ to all traffic around them...
for every gallon you save, other drivers waste 10...not to mention the accidents hypermilers cause
carefully watch the traffic around you ... you are causing grief for everyone around you ...
go with the flow is the best for all
scott
scott
scott
scott
Can you expand on this? I love the way the car drives in sport mode, but have been avoiding it to keep fuel economy as high as possible. (So far I have 170 miles on my tank, and only two "bars" down). I would think the increased throttle sensitivity (and whatever's going on with the exhaust to make it pop and burble all the time) would decrease mileage, whatever the shift point is.
Otherwise, the sport button is only changing the throttle mapping. I know I'm not alone in the opinion that the increased sensitivity of the throttle with the sport button on actually increases my ability to control the throttle. And with better control of the throttle, I can avoid getting into it harder than necessary. Clearly this may not be true for everyone - some folks like the control better with sport off. The point being the sport button and/or throttle mapping in itself is not going to affect your gas mileage. It is going to come down to how well you control the throttle.
At MINI we have always been about using less. And not because it's topical. Or fashionable. Or because everyone else is doing it. We were small when everyone else was going big. We were fuel-efficient before anyone else was thinking about it. And as we move forward we will continue to lead the way in trying to reduce our impact without sacrificing the very things that make a MINI a MINI.
The year was 1957, and in post-World War II England the Suez Canal Crisis had sent fuel prices soaring, leading many to start wondering if the large, gas-guzzling vehicles of the day made much sense. So Sir Leonard Lord of the Morris Company issued his top engineer, Alec Issigonis, a challenge: design and build a small, fuel-efficient car capable of carrying four adults, within economic reach of just about anyone. And though no one could have known it at the time, this challenge to find the perfect balance of fuel efficiency, functionality and fun wound up being the inspiration for an automotive and cultural icon: the Classic Mini.
And imo, driving a MINI fast vs driving a MINI fast AND maximizing fuel efficiency is like the difference between driving a car around a circle making only left hand turns vs driving a car around a circuit that requires both left and right hand turns. Much more of a challenge to try to maximize all the functionality of the MINI.
Hmm, guess I do need to get with the times and modify that. I forgot that the newer models have the pop and burble which is burning some extra gas. So maybe for very late models that have that option, keeping sport off may be worth it even in a manual.
I'm not familiar with the mechanics of the pop and burble...is the combustion taking place in the exhaust system rather than the combustion chamber, which is wasted energy since it's not being used to move the piston? However, it usually occurs when letting off the throttle (engine braking), where the fuel supply is cut by the computer anyways (right?).
I guess it depends where you are hyper mileage that depends if it is safe or not. If you are on the freeway doing say 60-65 in the right hand lane I see no problem with that. Even if you are doing the same thing on a surface street out of the faster peoples way there is no issue. But if you jump on the freeway get in the left lane and go the minium of 40mph then there is a big problem. You will probably be run down by some jack *** doing triple digits if not you will probably be shot by some lunatic. When I am commuting back and forth to work I try to save as much gas as possible but, on the weekends that is out the door.
I don't worry about the gas. We bought our cars for fun. Even having fun they get pretty good fuel economy. If I was worried about the gas or couldn't afford it I would have bought some other uninspiring brand of car.
As it is were miles ahead of the guy that drives his F250 truck back and forth to work cause he's cool and has no real need for the truck except for the look at me factor.
This is a physics FACT!
(you may try to say that exceeding your available traction due to speeding but the root cause is still the speed differential between tires and surface)
I find nothing wrong with getting the best efficiency out of your vehicle but being a hinderance to traffic is NOT the answer. Some vehicles hit a sweetspot for MPG higher than our MINIs. My BMW is 67mph, the 300zx was 71mph, MINI is 58mph... you get the idea.
Suggested:
-Diet for you (unless you are 12% BF or less, gotta be healthy)
-Diet for car (remove rear seats, tool kit, spare if equipped, light wheels)
-Narrow LRR tires inflated to slightly elevated psi
-Lowering springs (aerodynamics)
Speed differential may be the proximate cause of damage and injuries, but speed differential between a car and the road/trees/walls (and other stationary objects) is frequently a significant contributor. And I still contend that several orders of magnitude more accidents are caused or contributed to by excessive speed than by excessive slowness.
But if you want to drive your MINI fast, that's cool with me. Just don't crawl up my butt when I'm cruising at a slower speed in the right lane, trying to react well in advance to traffic and road conditions.
You enjoy your car your way, I'll enjoy mine my way.
And it's fun taking junctions between freeways at 50+, especially the ones that have a "suggested" speed of 25 MPH.
I read your blog, but didn't see your mpg for the tank. What were you able to achieve?
In my Justacooper, my worst avg tank (hand calculated, not using the OBC) is 36, and the best I averaged on a tank was 46.8 (out in the country, 55mph, flat country, no traffic to speak of (and I never drove under the limit, so no worries about being an impediment to the flow of traffic) and very few traffic lights. No special driving techniques except gentle throttle and some coasting before having to stop. Can't ask for much more than that!
