passenger side flooded footwell.
Left my windows cracked one day while at work. Thunderstorm rolled in... yep, an inch or so of rain on the floorboards.
Wet/Dry vac, blot the carpeting with towels, then let it air out. Mine was dry in 12 hours with no sign of mold, funny smell, or anything.
Question is, where did your water come from ??
had exactly the same thing happen to me a few weeks ago. only on the passenger side, tons of water after a rainstorm so I concluded it had to be some drain related issue. Had my shop check it out, turns out the passenger sunroof drain (if you open the sunroof you can see them close to where the sunroof curves to the top) was disconnected and so all the water would just leak into the passenger footwell and soak the carpets. They had to order a 5 dollar part and do 3 hours of labor, pulling down the headliner apparently takes a long time, to fix it. I was quoted 2.5 hours by mini of stl, 4 hours at the shop but i talked them down to 3 hours max.
Check the to cassette where the water drains in the corners. Sunroof drain tubes. They can clog with debris and such. There are two in the front and two in the rear. #10 and #11 in pics.
Here is the fix kit for the front drains::
https://www.ecstuning.com/b-ecs-part...51738197504kt/
Gen 1 R50 / R53 MINI Cooper Models:::
http://www.ecstuning.com/Search/51738197504/ #10
http://www.ecstuning.com/Search/54107043425/ES156702/ #11
Also if they are clean and look ok the drain tube might be leaking. You have to get behind the headliner and A pillars to see. Since its in the front you will want to check #10 connection as the problem.
Click Here for how to: https://www.northamericanmotoring.co...of-drains.html
For Gen 2 R55 R56 MINI models , they have they same general set up as the Gen 1. Check the connection at the hose to the tray and also check to see if debris clogged the sunroof tray near the hose connection.
#2 in the diagram
Rear # 3 Water outlet hose rear 272 mm size.
http://www.ecstuning.com/Search/SiteSearch/54107043425/
or
Rear # 3 Water outlet hose rear 739 mm size.
http://www.ecstuning.com/Search/SiteSearch/54137174869/
Match up the size length to the old one if replacing.
Thanks and hope that helps.
#2 in the diagram
or
You are welcome. Glad I could help.
