Lemforder or BSH lower motor mounts..and Hi im new here
im in need of a lower engine mount and i am interested in the BSH motor mounts. i also found Lemforders but i could not get any info on these. are they any good, theyre 32$ bucks on amazon, and BSH are 119$ on outmotoring.
also i couldnt find the introduce yourself thread so ill do it here, im briam from New York City, and im new to a dark silver R53!
Hello and welcome.
I can help you with the options. We carry lemfoder , its a OE manufacturer of the lower mount, then you can use the Powerflex bushing inserts to tighten things up, they come in the Performance and Race ( track ). Most people use the performance as the race is stiff and used for mostly track cars.
Lower Engine Rubber Mount
http://www.ecstuning.com/Search/SiteSearch/22116756406/ES261050/
Powerfelx:
This is the larger insert bushing and goes on the large end.
http://www.ecstuning.com/Search/SiteSearch/PFF5-107/
This one is a replacement bushing and goes on the smaller end.
http://www.ecstuning.com/Search/SiteSearch/PFF5-104/
Thanks and hope that helps.
Powerfelx:
You are welcome.
I notice that you have Lemfoerder, a replacement for the factory original upper motor mount. Looking at the pics it looks exactly the same, so do you consider your motor mount better than original, and if so what differentiates your mount vs the factory?
Lemforder is just an OE manufacturer, just another supplier that make the same part as OEM or Genuine MINI dependent on what it is. They are a good option for people as a price alternative.
I think you are talking about this one. Form 12/2003+ production. That set on the passenger upper side.
Upper Engine Mount # 3 in the diagram. Part # 22116778610
http://www.ecstuning.com/Search/SiteSearch/22116778610/
The long lower bolt that connect through the side of the front support tube on the chassis is below , its not included, as you can see our pics.
Its here: #5 in the diagram Part # 22116766753 And we currentley have it in stock.
http://www.ecstuning.com/Search/SiteSearch/22116766753/
Thanks and I hope that helps.
loop4re7
10-05-2015 09:53 PM
minipopkart
08-13-2015 05:22 AM
