N18 or N14
Best way is to simply look at the top of the motor...the plastic covers are different...
If I recall the n18 is "smooth", meaning the sparkplug coils are more hidden, and the n14 is more shaped...you can see more..hard to describe...but a few pictures are around side by side to show the differences....
The N18 had some revisions and the engine is slightly better in some areas. I wouldn't say it's bulletproof though. But better than the N14 in the area of the timing chain issues that occur with those engines.
Both have issues...both HAVE advantages....
Tuning and modding is better on the n14....
Mpg is better on the n18...which is mostly a revised n14 with variable valve timing on BOTH the intake and exhaust... This also greatly reduces carbon issues, as does a revised pcv system....
Good luck...having both cars side by side is a unique opportunity that few have had!! Enjoy!!
Both have issues...both HAVE advantages.... Tuning and modding is better on the n14.... Mpg is better on the n18...which is mostly a revised n14 with variable valve timing on BOTH the intake and exhaust... This also greatly reduces carbon issues, as does a revised pcv system.... Good luck...having both cars side by side is a unique opportunity that few have had!! Enjoy!!
I think tuning is pretty good for the N18 too. There's BMS, NM, RennTech, PAW, and Group4auto(looking at them strongly by the summer if BMS doesn't come out with the JB4). People complain about pricing so that also affects the decision making on the N18. Custom tuning is a bit better on the N14, but the more power and boost I've seen on some N14s isn't worth throwing a rod or paying $5-7k on a new engine lol. If people do tune their MCS then stick to 16-18psi, no higher than that, otherwise you'll get a case of boost spike and bye bye engine(aka Gabriel's car).
This is like a foreign language to me.. you are adding the N18 OEM noisemaker to your N14? What is the noisemaker?
The n14 can be tuned with the Cobb/alta access port....
The n18 made odb tuning impossible... That is WHY the access port was discontinued...
Use caution....the 3 tunes that come on the access port are ok...but do not use the "race" or stage 3 unless you have aftermarket pistons...the skirt on them fail...granading the motor after a bit...the stage 3 tune is simply too much for the stock internals for more than a few minutes/miles.
NorthWestEuro
10-21-2015 08:11 PM
